Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
Results 1 to 3 of 3
Thread: Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
    Dec 2016
    Default Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
    Our hot wire cnc machine wire will not get hot, need repair technician asap or if you have any suggestions for things we can do ourselves. Thank you!
    Jun 2013
    Default Re: Wire has stopped getting hot - ABF Aixia Croma Pro Foam Cutter
    Fuses. Breakers. Power.
    Sent from my SM-N970F using Tapatalk
    Dec 2016
    Quote Originally Posted by boydage View Post
    Thank you! Yes, we have checked all of the components you mentioned, everything is confirmed to be working except for the wire temperature. Thanks!
