Anilam 3000 Touch Info needed, Not starting coolant with MCode command
Results 1 to 2 of 2
Thread: Anilam 3000 Touch Info needed, Not starting coolant with MCode command
    May 2010
    Default Anilam 3000 Touch Info needed, Not starting coolant with MCode command
    Hello, we have a Fryer mill with Anilam 3000 controller. Recently we had to have the motion control board replaced and the place that serviced it also had to reinstall software I think. Before it left here it was jerking in the X and Y axis when moving but everything else worked fine. Got it back yesterday and all of that is fixed but now it's not reading a MCode 8 to turn the coolant on. Does anyone know if there is a setting or something that has to be turned on to make it read that? I wouldn't really think so but with Anilam you never know.
    thanks!
    Member Januaryrust's Avatar
    Jul 2020
    Default Re: Anilam 3000 Touch Info needed, Not starting coolant with MCode command
    CanBus setup?
    nathandive's Avatar
    Mar 2021
    Seahorse Swim School teaches water safety while increasing overall fitness. Private, semi-private, small groups a non-competitive swim team and parent-tot lessons are taught with patience, encouragement, and expertise. Seahorse Swim School’s goal is to encourage water safety, water confidence and overall fitness in Santa Cruz County.
