- Feeler VB 1100A Coolant Distribution.
Hi all, I am currently working on a Methods Feeler VB-1100A and I need some help locating the coolant distribution block. The flow to the coolant nozzles on the head is inadequate and I need to clean the distribution block. If anyone could point me in the right direcion of where I can find it that would be great.
Edit: Looking for the manifold to clean out check valve.
Thanks,
Chandler.
CNC Maintenance Tech.
- You may not post replies
- You may not edit your posts
Forum Rules
