SAUTER Colision during pivoting. Foult pre-indexation
Results 1 to 1 of 1
Thread: SAUTER Colision during pivoting. Foult pre-indexation
    Mar 2016
    Poland
    Default SAUTER Colision during pivoting. Foult pre-indexation
    Hi!
    One of my employee did colision during tool changing on my SAUTER 0.5.901.020
    Manual says tat if You have Foult pre-indexation you have to use hexagonal wrench on motor to unlock the turret and change position to T1.
    if position is reached you have tu push manually pre-indexation bolt to lock it on T1. Than run the lathe and change to another T.
    I did it but I still have "foult pre-indexation".and I can not change T for next one.
    What should I du ?
    Do you have any ideas.or experiences ?
    Manual attached
    LC
    Attached Files Attached Files
