call yamezen.
but that machine is B00 right, meaning its just using a regular pc motherboard? i thought the software was on a flash card?
hello everyone
I replaced NC PCB, on my Brother TC-32B. I have to upgarade software to newest version, where can I find software files? Should I write to brother service and ask for it?
call yamezen.
You're right is B00. Look at the alarm appear after NC PCB replacement.
0096 **Version error
Alarm cause: the combination of main/slave/local versions is not correct because NC board has been replaced.
Recovery method:
1. Revert to the original part
2. Upgrade software.
ah.
did you not buy the exact same board? or did you try to use just any old pc board?
i expect the original board has custom firmware that needs to be present.
ah ok.
call yamazen then. i guess there needs to be some form of software update.
