Need help on a DoAll c-4100 nc bandsaw
Results 1 to 4 of 4
Thread: Need help on a DoAll c-4100 nc bandsaw
    Member Mfonseca90's Avatar
    Sep 2019
    Default Need help on a DoAll c-4100 nc bandsaw
    I apologize if this is in the wrong section. I’m new to the forum and could not find a section to ask questions for bandsaws. If I am in the wrong section please point me in the right direction. I’m having problems with the saw shutting the hydraulic pump off after running for 50secs. It’ll start right back up, but after another 50secs it’ll shut off again. Any suggestions would be really appreciated.
    Dec 2013
    Default Re: Need help on a DoAll c-4100 nc bandsaw
    Low oil? Clogged filter? Bad motor? Bad pump? Bad pressure switch? Bad pressure relief valve?
    Could be any of the above. Hard to tell without some trouble shooting.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2019
    Quote Originally Posted by Jim Dawson View Post
    Oil level is good, checked to see how many amps the motor pulls while cutting, most it pulls is 2.2amps. Pump is a little noisy. I’ll check the pressure switch and filter. It doesn’t really matter what it cuts, after 50secs It’ll shut off. Saw head feeds properly, clamps operate properly, index vise shuttles back and forth properly. saw head returns up properly, not slow like if the pressure was low. It only happens while cutting.
    Dec 2013
    You are going to have to see if the pressure switch is dropping it out. Any error messages on the screen?
    Jim Dawson
    Sandy, Oregon, USA
