Matching pulleys
Results 1 to 5 of 5
Thread: Matching pulleys
    Registered EKFER's Avatar
    Apr 2011
    Default Matching pulleys
    Dear SDP/SI: In matching the pulley size for 10mm ball screws and 3/8 nema motor shafts, I selected 5.08mm and .200 inch pitch pulleys with 15 grooves respectively. Will there be a problem if I use 3/8 belts for them? Thank you
    Gold Member
    Jan 2005
    EKFER
    Do you mean 3/8 wide belt or 3/8 pitch, if it is pitch then it is not correct, you have to use .200 pitch Belts, & also mixing the pulleys can some times be a problem as well as some metric Pitch pulleys, have a different tooth profile, even though both you have end up with the same Pitch, they may have a different tooth profile
    So they should never be mixed unless you know for sure the tooth profile is the same
    Mactec54
    Apr 2011
    You are correct. It is a 3/8 belt. I tried to find a metric pulley with an equivalent id of 3/8, which is the nema 23 motor shaft size. However, I couldn't find one. The belt fits really close in both types of pulleys. I'll write back when I assemble the machine. Thank you
    Gold Member
    Jan 2005
    EKFER
    A 3/8 Pitch belt won't even be close .200 Pitch pulleys, .375 Pitch Belt=.175 difference it is not going to work
    You should be using 5mm GT2 Pulleys & belts, for what you are doing, You almost always have to bore the pulleys, to suit what you are going to put them on, attached is just for a guide there are many sizes, but don't expect to get one that fits without it being bored to the size you need
    Attached Thumbnails Attached Thumbnails Matching pulleys-5mm-gt2-pulleys-jpg
    Mactec54
    Gold Member
    Jun 2010
    Default Re: Matching pulleys
    That did worry me at first, but I found that even with Chinese eBay pulleys (GT2, 2 mm pitch, 30 T), the rim was really concentric to the stock bore. So boring out to size was quite easy.
    Cheers
    Roger
Matching pulleys
Matching pulleys
