Mach3 Router Screen.
Results 1 to 5 of 5
Thread: Mach3 Router Screen.
    Mar 2003
    Shelby Township
    Default Mach3 Router Screen.
    As I mentioned last week, I was throwing together a router Screen for Mach3. This should have all the functions needed for a router, without all the extra clutter in the standard mach3 screens. I haven't really tested it, but I think everything is working.
    There is no toolpath on the Run screen. The reason for this is that CPU usage is about 75% lower without the toolpath on the screen, and when your cutting, you're usually looking at the machine, not the screen. This should make this screen run better on slower PC's than the standard screens.
    Unzip all the .png files to Mach3\Bitmaps\Router\ and put the Router.set file in the mach3 folder. It's setup for spindle to use Output 1 and Coolant Output 2.
    Let me know if there are any issues and I'll fix em up.
    http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router.zip
    Also, here's the Real Draw Pro files if anyone wants to modify the Screens (you'll need RealDraw Pro).
    http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router_RealDraw_Pro.zip
    Attached Thumbnails Attached Thumbnails Mach3 Router Screen.-router_load-jpg   Mach3 Router Screen.-router_run-jpg   Mach3 Router Screen.-router_settings-jpg
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Registered tauntdesigns's Avatar
    Nov 2005
    I don't have a router, but I do like the look of this screen set. Thanks!
    Cheers,
    Jack
    Walking is highly over-rated
    Gold Member lovebugjunkie's Avatar
    Apr 2005
    Thanks for taking the time to do this. Very nice GUI, will give it a try tomorrow.
    george
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    beautiful yet simple...thanks Gerry for sharing ur hardwork...
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    Good work Gerry. I recognize that RealDraw flavor about it.
    Being outside the square !!!
