New Machine Build Mach3 1080 x 1920 Portrait Screen Issue
Results 1 to 5 of 5
Thread: Mach3 1080 x 1920 Portrait Screen Issue
    Member Saintgp's Avatar
    Jun 2019
    Default Mach3 1080 x 1920 Portrait Screen Issue
    Hi Peeps
    im busy with my new cnc build https://www.cnczone.com/forums/cnc-d...ntry-mill.html
    i need a screen that works in portrait for 1080 x 1920 resolution
    ive been trying to rearrange the original mach3 screen set, using Screen4 but screen keeps moving down about half way down the screen
    any ideas on how to rectify this problem
    Nov 2013
    Default Re: Mach3 1080 x 1920 Portrait Screen Issue
    Mach3 is now many years old and all development ceased on it seven years ago.
    One of the area where it was always, and still is, traditionally weak is its screen editing.
    Try downloading Mach4 and see what a modern piece of software can do for you....screen editing is just the tip of the iceberg.
    Craig
    Jan 2018
    United Kingdom
    Quote Originally Posted by Saintgp View Post
    Hi Peeps
    Doubtful.
    It's old software.
    And old software is designed for 1024x768.
    I have many good 15 year old software programs that don't work properly on 1920x1080.
    Member CitizenOfDreams's Avatar
    Nov 2012
    I made my portrait screens with MachScreen - which is slightly less terrible than Screen4. My resolution is only 768*1024 though, so I don't know whether MachScreen will work with 1080*1920.
    Also, try turning on "Hi-Res screens" and turning off "Auto resize" in Mach3 settings (if you haven't already).
    Jun 2019
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks Buddy
    i changed to machscreen. it seems to be more stable. will have to play arround a bit but i think it will work for what i need
