SolidCam to Mach4 Lathe PP arc problems
Results 1 to 3 of 3
Thread: SolidCam to Mach4 Lathe PP arc problems
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default SolidCam to Mach4 Lathe PP arc problems
    I got the PP I have from this thread. I only added G99 for feed per rotation. No problem there. It works. The problem occurs when the model have curvy lines which makes Mach4 crazy. Please see the attached screenshots. Generated g-code is also attached.
    All other posts without "R" works fine.
    I tried to change "Arc Center Mode" to "Absolute" and "Incremental" in Mach4 but it didn't help.
    What else can I try?
    Any help will be appreciated.
    Note: The first 2 images are from SolidCam simulator. The last image is from Mach4 when I load the generated g-code.
    Suat
    Attached Thumbnails Attached Thumbnails SolidCam to Mach4 Lathe PP arc problems-solidcam_sim_arcs-jpg   SolidCam to Mach4 Lathe PP arc problems-solidcam_arcs-jpg   SolidCam to Mach4 Lathe PP arc problems-mach4_arcs-jpg
    Attached Files Attached Files
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Mar 2014
    Turkey
    Default Re: SolidCam to Mach4 Lathe PP arc problems
    I managed to get it working. Swapped G2 and G3. Also swapped arc direction.
    Sent from my MI 5s Plus using Tapatalk
    Suat
    Mar 2014
    Turkey
    Yeah, it definitely works. If anyone need it, let me know. I'll share, for free of course. I'm not one of those PP sellers.
    Suat
