Problem MACH3/FEEDRATE
Results 1 to 16 of 16
Thread: MACH3/FEEDRATE
    Oct 2007
    Default MACH3/FEEDRATE
    Hi, have been using your screen set since2010 and it is working perfectly.
    I know that my problem isn’t coming from the screen set, Mach doesn’t recognize the federate that I’m asking, no mather if I set to 15 or 1500 it’s always crawling, I can hardly see it move.
    When I press the arrows or use my shuttle it moves normally.
    Any suggestion of what I should look at to fix it.
    Thank you
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: MACH3/FEEDRATE
    Is it moving slow when running g-code?
    Post the code.
    UCCNC 2017 Screenset
    Oct 2007
    Thank you for the prompt reply, it's only slow while processing the G-Codes, jogging is normal . I was reading your comments on another tread that Kernel frequency on the diagnostics page and see if it's running at 75% speed. (18750 instead of 25000) and make sure FRO is set to 100%, and rapid override too, mine is right on the target.
    N10 (##01 ARRONDI 3.5 A 2.5 ##)
    N20 (##02 Produced by Rich's Indexer Wizards Version 2.0 ##)
    N30 (##03 06/17/2019 1:13:53 AM ##)
    N40 (##11 GCode start header code ##)
    N50 G20 (Inch units)
    N60 G17 (XY plane select)
    N70 G90 (Absolute mode)
    N80 G40 (Cancel cutter radius compensation)
    N90 G49 (Cancel tool length offset)
    N100 G80 (Cancel motion mode)
    N110 M03 (Spindle on)
    N120 (##12 GCode end header code ##)
    N130 (##21 Rounding ##)
    N140 (##22 ARRONDI 3.5 A 2.5 ##)
    N150 (##23 Name = X start, Value = 0, Integer = False, Positive = False, Type = NumEdit ##)
    N160 (##23 Name = X end, Value = .5, Integer = False, Positive = False, Type = NumEdit ##)
    N170 (##23 Name = Rough diameter, Value = 3.625, Integer = False, Positive = True, Type = NumEdit ##)
    N180 (##23 Name = Start diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N190 (##23 Name = End diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N200 (##23 Name = Z depth per pass, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N210 (##23 Name = Rapid diameter, Value = 3.7, Integer = False, Positive = True, Type = NumEdit ##)
    N220 (##23 Name = Stepover, Value = .05125, Integer = False, Positive = True, Type = NumEdit ##)
    N230 (##23 Name = Feed rate, Value = 150, Integer = False, Positive = True, Type = NumEdit ##)
    N240 (##23 Name = Plunge rate, Value = 20, Integer = False, Positive = True, Type = NumEdit ##)
    N250 (##23 Name = Rotary axis rotation;CW;CCW, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N260 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 0, Integer = True, Positive = True, Type = RadioGroup ##)
    N270 G0 Z1.85
    N280 G0 A0
    N290 G0 X0 Y0
    N300 (Z pass 1)
    N310 G0 Z1.8125
    N320 G1 Z1.7500 F20
    N330 G93
    N340 G1 A360 F13.6418522650196
    N350 G92 A0
    N360 G1 X0.5 A3512.1951219512195121951219514 Z1.7500 F1.3982746687639898563027601802
    N370 G1 A3872.1951219512195121951219514 F13.6418522650196
    N380 G94
    N390 G92 A3512.1951219512195121951219514
    N400 G0 Z1.85
    N410 G0 A3240
    N420 G92 A0
    N430 G0 X0
    N440 (Z pass 2)
    N450 G0 Z1.8125
    N460 G1 Z1.6875 F20
    N470 G93
    N480 G1 A360 F14.1471060526129
    N490 G92 A0
    N500 G1 X0.5 A3512.1951219512195121951219514 Z1.6875 F1.4500614311377068991515178026
    N510 G1 A3872.1951219512195121951219514 F14.1471060526129
    N520 G94
    N530 G92 A3512.1951219512195121951219514
    N540 G0 Z1.85
    N550 G0 A3240
    N560 G92 A0
    N570 G0 X0
    N580 (Z pass 3)
    N590 G0 Z1.8125
    N600 G1 Z1.6250 F20
    N610 G93
    N620 G1 A360 F14.691225516175
    N630 G92 A0
    N640 G1 X0.5 A3512.1951219512195121951219514 Z1.6250 F1.5058316455114687132266307989
    N650 G1 A3872.1951219512195121951219514 F14.691225516175
    N660 G94
    N670 G92 A3512.1951219512195121951219514
    N680 G0 Z1.85
    N690 G0 A3240
    N700 G92 A0
    N710 G0 X0
    N720 (Z pass 4)
    N730 G0 Z1.8125
    N740 G1 Z1.5625 F20
    N750 G93
    N760 G1 A360 F15.278874536822
    N770 G92 A0
    N780 G1 X0.5 A3512.1951219512195121951219514 Z1.5625 F1.5660633015035327039672687998
    N790 G1 A3872.1951219512195121951219514 F15.278874536822
    N800 G94
    N810 G92 A3512.1951219512195121951219514
    N820 G0 Z1.85
    N830 G0 A3240
    N840 G92 A0
    N850 G0 X0
    N860 (Z pass 5)
    N870 G0 Z1.8125
    N880 G1 Z1.5000 F20
    N890 G93
    N900 G1 A360 F15.9154943091895
    N910 G92 A0
    N920 G1 X0.5 A3512.1951219512195121951219514 Z1.5000 F1.6313140482163393719263481673
    N930 G1 A3872.1951219512195121951219514 F15.9154943091895
    N940 G94
    N950 G92 A3512.1951219512195121951219514
    N960 G0 Z1.85
    N970 G0 A3240
    N980 G92 A0
    N990 G0 X0
    N1000 (Z pass 6)
    N1010 G0 Z1.8125
    N1020 G1 Z1.4375 F20
    N1030 G93
    N1040 G1 A360 F16.6074723226326
    N1050 G92 A0
    N1060 G1 X0.5 A3512.1951219512195121951219514 Z1.4375 F1.7022385100000901090128867227
    N1070 G1 A3872.1951219512195121951219514 F16.6074723226326
    N1080 G94
    N1090 G92 A3512.1951219512195121951219514
    N1100 G0 Z1.85
    N1110 G0 A3240
    N1120 G92 A0
    N1130 G0 X0
    N1140 (Z pass 7)
    N1150 G0 Z1.8125
    N1160 G1 Z1.3750 F20
    N1170 G93
    N1180 G1 A360 F17.3623574282068
    N1190 G92 A0
    N1200 G1 X0.5 A3512.1951219512195121951219514 Z1.3750 F1.7796103241822267311859206666
    N1210 G1 A3872.1951219512195121951219514 F17.3623574282068
    N1220 G94
    N1230 G92 A3512.1951219512195121951219514
    N1240 G0 Z1.85
    N1250 G0 A3240
    N1260 G92 A0
    N1270 G0 X0
    N1280 (Z pass 8)
    N1290 G0 Z1.8125
    N1300 G1 Z1.3125 F20
    N1310 G93
    N1320 G1 A360 F18.1891363533595
    N1330 G92 A0
    N1340 G1 X0.5 A3512.1951219512195121951219514 Z1.3125 F1.8643504745410071181004835521
    N1350 G1 A3872.1951219512195121951219514 F18.1891363533595
    N1360 G94
    N1370 G92 A3512.1951219512195121951219514
    N1380 G0 Z1.85
    N1390 G0 A3240
    N1400 G92 A0
    N1410 G0 X0
    N1420 (Z pass 9)
    N1430 G0 Z1.8125
    N1440 G1 Z1.2500 F20
    N1450 G93
    N1460 G1 A360 F19.0985931710274
    N1470 G92 A0
    N1480 G1 X0.5 A3512.1951219512195121951219514 Z1.2500 F1.9575641237111623009766880575
    N1490 G1 A3872.1951219512195121951219514 F19.0985931710274
    N1500 G94
    N1510 G92 A3512.1951219512195121951219514
    N1520 G0 Z1.85
    N1530 G0 A3240
    N1540 G92 A0
    N1550 G0 X0
    N1560
    N1570
    N1580 (##25 Rounding end ##)
    N1590 (##21 Rounding ##)
    N1600 (##22 ARONDI DEBUT ##)
    N1610 (##23 Name = X start, Value = .5, Integer = False, Positive = False, Type = NumEdit ##)
    N1620 (##23 Name = X end, Value = .6875, Integer = False, Positive = False, Type = NumEdit ##)
    N1630 (##23 Name = Rough diameter, Value = 3.5, Integer = False, Positive = True, Type = NumEdit ##)
    N1640 (##23 Name = Start diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N1650 (##23 Name = End diameter, Value = 3.45, Integer = False, Positive = True, Type = NumEdit ##)
    N1660 (##23 Name = Z depth per pass, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N1670 (##23 Name = Rapid diameter, Value = 3.6, Integer = False, Positive = True, Type = NumEdit ##)
    N1680 (##23 Name = Stepover, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N1690 (##23 Name = Feed rate, Value = 150, Integer = False, Positive = True, Type = NumEdit ##)
    N1700 (##23 Name = Plunge rate, Value = 20, Integer = False, Positive = True, Type = NumEdit ##)
    N1710 (##23 Name = Rotary axis rotation;CW;CCW, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N1720 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 0, Integer = True, Positive = True, Type = RadioGroup ##)
    N1730 G0 Z1.8
    N1740 G0 A0
    N1750 G0 X0.5 Y0
    N1760 (Z pass 1)
    N1770 G0 Z1.75
    N1780 G1 Z1.6875 F20
    N1790 G93
    N1800 G1 A360 F14.1471060526129
    N1810 G92 A0
    N1820 G1 X0.6875 A1080 Z1.746875 F4.6340971178220049021885065655
    N1830 G1 A1440 F13.6662562941162
    N1840 G94
    N1850 G92 A1080
    N1860 G0 Z1.8
    N1870 G0 A1080
    N1880 G92 A0
    N1890 G0 X0.5
    N1900 (Z pass 2)
    N1910 G0 Z1.75
    N1920 G1 Z1.6250 F20
    N1930 G93
    N1940 G1 A360 F14.691225516175
    N1950 G92 A0
    N1960 G1 X0.6875 A1080 Z1.743750 F4.7243686187991871134559182254
    N1970 G1 A1440 F13.6907477928512
    N1980 G94
    N1990 G92 A1080
    N2000 G0 Z1.8
    N2010 G0 A1080
    N2020 G92 A0
    N2030 G0 X0.5
    N2040 (Z pass 3)
    N2050 G0 Z1.75
    N2060 G1 Z1.5625 F20
    N2070 G93
    N2080 G1 A360 F15.278874536822
    N2090 G92 A0
    N2100 G1 X0.6875 A1080 Z1.740625 F4.8182268754196200359791695912
    N2110 G1 A1440 F13.7153272323357
    N2120 G94
    N2130 G92 A1080
    N2140 G0 Z1.8
    N2150 G0 A1080
    N2160 G92 A0
    N2170 G0 X0.5
    N2180 (Z pass 4)
    N2190 G0 Z1.75
    N2200 G1 Z1.5000 F20
    N2210 G93
    N2220 G1 A360 F15.9154943091895
    N2230 G92 A0
    N2240 G1 X0.6875 A1080 Z1.737500 F4.9158899852086396706006452113
    N2250 G1 A1440 F13.7399950870701
    N2260 G94
    N2270 G92 A1080
    N2280 G0 Z1.8
    N2290 G0 A1080
    N2300 G92 A0
    N2310 G0 X0.5
    N2320 (Z pass 5)
    N2330 G0 Z1.75
    N2340 G1 Z1.4375 F20
    N2350 G93
    N2360 G1 A360 F16.6074723226326
    N2370 G92 A0
    N2380 G1 X0.6875 A1080 Z1.734375 F5.0175940934361001796078260334
    N2390 G1 A1440 F13.7647518349747
    N2400 G94
    N2410 G92 A1080
    N2420 G0 Z1.8
    N2430 G0 A1080
    N2440 G92 A0
    N2450 G0 X0.5
    N2460 (Z pass 6)
    N2470 G0 Z1.75
    N2480 G1 Z1.3750 F20
    N2490 G93
    N2500 G1 A360 F17.3623574282068
    N2510 G92 A0
    N2520 G1 X0.6875 A1080 Z1.731250 F5.1235952993450160478959779022
    N2530 G1 A1440 F13.7895979574205
    N2540 G94
    N2550 G92 A1080
    N2560 G0 Z1.8
    N2570 G0 A1080
    N2580 G92 A0
    N2590 G0 X0.5
    N2600 (Z pass 7)
    N2610 G0 Z1.75
    N2620 G1 Z1.3125 F20
    N2630 G93
    N2640 G1 A360 F18.1891363533595
    N2650 G92 A0
    N2660 G1 X0.6875 A1080 Z1.728125 F5.2341718091954031650691172477
    N2670 G1 A1440 F13.8145339392604
    N2680 G94
    N2690 G92 A1080
    N2700 G0 Z1.8
    N2710 G0 A1080
    N2720 G92 A0
    N2730 G0 X0.5
    N2740 (Z pass 8)
    N2750 G0 Z1.75
    N2760 G1 Z1.2500 F20
    N2770 G93
    N2780 G1 A360 F19.0985931710274
    N2790 G92 A0
    N2800 G1 X0.6875 A1080 Z1.725000 F5.34962637422779653791093918
    N2810 G1 A1440 F13.8395602688605
    N2820 G94
    N2830 G92 A1080
    N2840 G0 Z1.8
    N2850 G0 A1080
    N2860 G92 A0
    N2870 G0 X0.5
    N2880
    N2890 (##25 Rounding end ##)
    N2900 (##21 Rounding ##)
    N2910 (##22 ARRONDI FIN 3.5 A 2.5 ##)
    N2920 (##23 Name = X start, Value = 1.3625, Integer = False, Positive = False, Type = NumEdit ##)
    N2930 (##23 Name = X end, Value = 1.55, Integer = False, Positive = False, Type = NumEdit ##)
    N2940 (##23 Name = Rough diameter, Value = 3.6, Integer = False, Positive = True, Type = NumEdit ##)
    N2950 (##23 Name = Start diameter, Value = 3.5, Integer = False, Positive = True, Type = NumEdit ##)
    N2960 (##23 Name = End diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N2970 (##23 Name = Z depth per pass, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N2980 (##23 Name = Rapid diameter, Value = 3.67, Integer = False, Positive = True, Type = NumEdit ##)
    N2990 (##23 Name = Stepover, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N3000 (##23 Name = Feed rate, Value = 150, Integer = False, Positive = True, Type = NumEdit ##)
    N3010 (##23 Name = Plunge rate, Value = 20, Integer = False, Positive = True, Type = NumEdit ##)
    N3020 (##23 Name = Rotary axis rotation;CW;CCW, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N3030 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 0, Integer = True, Positive = True, Type = RadioGroup ##)
    N3040 G0 Z1.835
    N3050 G0 A0
    N3060 G0 X1.3625 Y0
    N3070 (Z pass 1)
    N3080 G0 Z1.8
    N3090 G1 Z1.7944444444444444444444444444 F20
    N3100 G93
    N3110 G1 A360 F13.3039735711491
    N3120 G92 A0
    N3130 G1 X1.55 A1080 Z1.7388888888888888888888888889 F4.5043137838097433741733075909
    N3140 G1 A1440 F13.7290206500996
    N3150 G94
    N3160 G92 A1080
    N3170 G0 Z1.835
    N3180 G0 A1080
    N3190 G92 A0
    N3200 G0 X1.3625
    N3210 (Z pass 2)
    N3220 G0 Z1.8
    N3230 G1 Z1.7888888888888888888888888888 F20
    N3240 G93
    N3250 G1 A360 F13.3452902592583
    N3260 G92 A0
    N3270 G1 X1.55 A1080 Z1.6777777777777777777777777778 F4.590932376999049654321742421
    N3280 G1 A1440 F14.2290843161628
    N3290 G94
    N3300 G92 A1080
    N3310 G0 Z1.835
    N3320 G0 A1080
    N3330 G92 A0
    N3340 G0 X1.3625
    N3350 (Z pass 3)
    N3360 G0 Z1.8
    N3370 G1 Z1.7833333333333333333333333332 F20
    N3380 G93
    N3390 G1 A360 F13.3868643722155
    N3400 G92 A0
    N3410 G1 X1.55 A1080 Z1.6166666666666666666666666667 F4.6809476066353089496607458305
    N3420 G1 A1440 F14.7669534827532
    N3430 G94
    N3440 G92 A1080
    N3450 G0 Z1.835
    N3460 G0 A1080
    N3470 G92 A0
    N3480 G0 X1.3625
    N3490 (Z pass 4)
    N3500 G0 Z1.8
    N3510 G1 Z1.7777777777777777777777777776 F20
    N3520 G93
    N3530 G1 A360 F13.4286983233787
    N3540 G92 A0
    N3550 G1 X1.55 A1080 Z1.5555555555555555555555555556 F4.7745632568030668649601037712
    N3560 G1 A1440 F15.347083798147
    N3570 G94
    N3580 G92 A1080
    N3590 G0 Z1.835
    N3600 G0 A1080
    N3610 G92 A0
    N3620 G0 X1.3625
    N3630 (Z pass 5)
    N3640 G0 Z1.8
    N3650 G1 Z1.7722222222222222222222222220 F20
    N3660 G93
    N3670 G1 A360 F13.4707945563673
    N3680 G92 A0
    N3690 G1 X1.55 A1080 Z1.4944444444444444444444444445 F4.8719997455392321693925358784
    N3700 G1 A1440 F15.9746597155434
    N3710 G94
    N3720 G92 A1080
    N3730 G0 Z1.835
    N3740 G0 A1080
    N3750 G92 A0
    N3760 G0 X1.3625
    N3770 (Z pass 6)
    N3780 G0 Z1.8
    N3790 G1 Z1.7666666666666666666666666664 F20
    N3800 G93
    N3810 G1 A360 F13.5131555455383
    N3820 G92 A0
    N3830 G1 X1.55 A1080 Z1.4333333333333333333333333334 F4.9734958573452577140918909623
    N3840 G1 A1440 F16.6557498584542
    N3850 G94
    N3860 G92 A1080
    N3870 G0 Z1.835
    N3880 G0 A1080
    N3890 G92 A0
    N3900 G0 X1.3625
    N3910 (Z pass 7)
    N3920 G0 Z1.8
    N3930 G1 Z1.7611111111111111111111111108 F20
    N3940 G93
    N3950 G1 A360 F13.5557837964706
    N3960 G92 A0
    N3970 G1 X1.55 A1080 Z1.3722222222222222222222222223 F5.0793106968415379169364385754
    N3980 G1 A1440 F17.3975039007335
    N3990 G94
    N4000 G92 A1080
    N4010 G0 Z1.835
    N4020 G0 A1080
    N4030 G92 A0
    N4040 G0 X1.3625
    N4050 (Z pass 8)
    N4060 G0 Z1.8
    N4070 G1 Z1.7555555555555555555555555552 F20
    N4080 G93
    N4090 G1 A360 F13.5986818464594
    N4100 G92 A0
    N4110 G1 X1.55 A1080 Z1.3111111111111111111111111112 F5.1897258972115588706396633341
    N4120 G1 A1440 F18.2084045062762
    N4130 G94
    N4140 G92 A1080
    N4150 G0 Z1.835
    N4160 G0 A1080
    N4170 G92 A0
    N4180 G0 X1.3625
    N4190 (Z pass 9)
    N4200 G0 Z1.8
    N4210 G1 Z1.7499999999999999999999999996 F20
    N4220 G93
    N4230 G1 A360 F13.6418522650196
    N4240 G92 A0
    N4250 G1 X1.55 A1080 Z1.2500000000000000000000000001 F5.3050481230619134762282443135
    N4260 G1 A1440 F19.0985931710274
    N4270 G94
    N4280 G92 A1080
    N4290 G0 Z1.835
    N4300 G0 A1080
    N4310 G92 A0
    N4320 G0 X1.3625
    N4330
    N4340 (##25 Rounding end ##)
    N4350 (##21 Rounding ##)
    N4360 (##22 DIAM 2.5 ##)
    N4370 (##23 Name = X start, Value = 1.55, Integer = False, Positive = False, Type = NumEdit ##)
    N4380 (##23 Name = X end, Value = 3.25, Integer = False, Positive = False, Type = NumEdit ##)
    N4390 (##23 Name = Rough diameter, Value = 3.55, Integer = False, Positive = True, Type = NumEdit ##)
    N4400 (##23 Name = Start diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N4410 (##23 Name = End diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N4420 (##23 Name = Z depth per pass, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N4430 (##23 Name = Rapid diameter, Value = 3.6, Integer = False, Positive = True, Type = NumEdit ##)
    N4440 (##23 Name = Stepover, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N4450 (##23 Name = Feed rate, Value = 150, Integer = False, Positive = True, Type = NumEdit ##)
    N4460 (##23 Name = Plunge rate, Value = 20, Integer = False, Positive = True, Type = NumEdit ##)
    N4470 (##23 Name = Rotary axis rotation;CW;CCW, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N4480 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 0, Integer = True, Positive = True, Type = RadioGroup ##)
    N4490 G0 Z1.8
    N4500 G0 A0
    N4510 G0 X1.55 Y0
    N4520 (Z pass 1)
    N4530 G0 Z1.775
    N4540 G1 Z1.7166666666666666666666666667 F20
    N4550 G93
    N4560 G1 A360 F13.9067426002627
    N4570 G92 A0
    N4580 G1 X3.25 A9792.0 Z1.7166666666666666666666666667 F0.5112687183850391787840988989
    N4590 G1 A10152.0 F13.9067426002627
    N4600 G94
    N4610 G92 A9792.0
    N4620 G0 Z1.8
    N4630 G0 A9720
    N4640 G92 A0
    N4650 G0 X1.55
    N4660 (Z pass 2)
    N4670 G0 Z1.775
    N4680 G1 Z1.6583333333333333333333333334 F20
    N4690 G93
    N4700 G1 A360 F14.3959245007745
    N4710 G92 A0
    N4720 G1 X3.25 A9792.0 Z1.6583333333333333333333333334 F0.5292524091094659860638227825
    N4730 G1 A10152.0 F14.3959245007745
    N4740 G94
    N4750 G92 A9792.0
    N4760 G0 Z1.8
    N4770 G0 A9720
    N4780 G92 A0
    N4790 G0 X1.55
    N4800 (Z pass 3)
    N4810 G0 Z1.775
    N4820 G1 Z1.6000000000000000000000000001 F20
    N4830 G93
    N4840 G1 A360 F14.9207759148652
    N4850 G92 A0
    N4860 G1 X3.25 A9792.0 Z1.6000000000000000000000000001 F0.5485473372071975152483908252
    N4870 G1 A10152.0 F14.9207759148652
    N4880 G94
    N4890 G92 A9792.0
    N4900 G0 Z1.8
    N4910 G0 A9720
    N4920 G92 A0
    N4930 G0 X1.55
    N4940 (Z pass 4)
    N4950 G0 Z1.775
    N4960 G1 Z1.5416666666666666666666666668 F20
    N4970 G93
    N4980 G1 A360 F15.4853458143466
    N4990 G92 A0
    N5000 G1 X3.25 A9792.0 Z1.5416666666666666666666666668 F0.5693023340936252857478704911
    N5010 G1 A10152.0 F15.4853458143466
    N5020 G94
    N5030 G92 A9792.0
    N5040 G0 Z1.8
    N5050 G0 A9720
    N5060 G92 A0
    N5070 G0 X1.55
    N5080 (Z pass 5)
    N5090 G0 Z1.775
    N5100 G1 Z1.4833333333333333333333333335 F20
    N5110 G93
    N5120 G1 A360 F16.0943200879445
    N5130 G92 A0
    N5140 G1 X3.25 A9792.0 Z1.4833333333333333333333333335 F0.5916896404208541044278754969
    N5150 G1 A10152.0 F16.0943200879445
    N5160 G94
    N5170 G92 A9792.0
    N5180 G0 Z1.8
    N5190 G0 A9720
    N5200 G92 A0
    N5210 G0 X1.55
    N5220 (Z pass 6)
    N5230 G0 Z1.775
    N5240 G1 Z1.4250000000000000000000000002 F20
    N5250 G93
    N5260 G1 A360 F16.75315190441
    N5270 G92 A0
    N5280 G1 X3.25 A9792.0 Z1.4250000000000000000000000002 F0.6159096968039691376340716201
    N5290 G1 A10152.0 F16.75315190441
    N5300 G94
    N5310 G92 A9792.0
    N5320 G0 Z1.8
    N5330 G0 A9720
    N5340 G92 A0
    N5350 G0 X1.55
    N5360 (Z pass 7)
    N5370 G0 Z1.775
    N5380 G1 Z1.3666666666666666666666666669 F20
    N5390 G93
    N5400 G1 A360 F17.4682254613056
    N5410 G92 A0
    N5420 G1 X3.25 A9792.0 Z1.3666666666666666666666666669 F0.6421971612377911379527796282
    N5430 G1 A10152.0 F17.4682254613056
    N5440 G94
    N5450 G92 A9792.0
    N5460 G0 Z1.8
    N5470 G0 A9720
    N5480 G92 A0
    N5490 G0 X1.55
    N5500 (Z pass 8)
    N5510 G0 Z1.775
    N5520 G1 Z1.3083333333333333333333333336 F20
    N5530 G93
    N5540 G1 A360 F18.2470635391982
    N5550 G92 A0
    N5560 G1 X3.25 A9792.0 Z1.3083333333333333333333333336 F0.6708285359793758492218072936
    N5570 G1 A10152.0 F18.2470635391982
    N5580 G94
    N5590 G92 A9792.0
    N5600 G0 Z1.8
    N5610 G0 A9720
    N5620 G92 A0
    N5630 G0 X1.55
    N5640 (Z pass 9)
    N5650 G0 Z1.775
    N5660 G1 Z1.2500000000000000000000000003 F20
    N5670 G93
    N5680 G1 A360 F19.0985931710274
    N5690 G92 A0
    N5700 G1 X3.25 A9792.0 Z1.2500000000000000000000000003 F0.7021319295395563056151942624
    N5710 G1 A10152.0 F19.0985931710274
    N5720 G94
    N5730 G92 A9792.0
    N5740 G0 Z1.8
    N5750 G0 A9720
    N5760 G92 A0
    N5770 G0 X1.55
    N5780
    N5790
    N5800 (##25 Rounding end ##)
    N5810 (##21 Rounding ##)
    N5820 (##22 TAPER ##)
    N5830 (##23 Name = X start, Value = 1.55, Integer = False, Positive = False, Type = NumEdit ##)
    N5840 (##23 Name = X end, Value = 3.25, Integer = False, Positive = False, Type = NumEdit ##)
    N5850 (##23 Name = Rough diameter, Value = 2.55, Integer = False, Positive = True, Type = NumEdit ##)
    N5860 (##23 Name = Start diameter, Value = 2.5, Integer = False, Positive = True, Type = NumEdit ##)
    N5870 (##23 Name = End diameter, Value = 1.875, Integer = False, Positive = True, Type = NumEdit ##)
    N5880 (##23 Name = Z depth per pass, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N5890 (##23 Name = Rapid diameter, Value = 2.6, Integer = False, Positive = True, Type = NumEdit ##)
    N5900 (##23 Name = Stepover, Value = .0625, Integer = False, Positive = True, Type = NumEdit ##)
    N5910 (##23 Name = Feed rate, Value = 150, Integer = False, Positive = True, Type = NumEdit ##)
    N5920 (##23 Name = Plunge rate, Value = 20, Integer = False, Positive = True, Type = NumEdit ##)
    N5930 (##23 Name = Rotary axis rotation;CW;CCW, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N5940 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 0, Integer = True, Positive = True, Type = RadioGroup ##)
    N5950 G0 Z1.3
    N5960 G0 A0
    N5970 G0 X1.55 Y0
    N5980 (Z pass 1)
    N5990 G0 Z1.275
    N6000 G1 Z1.2708333333333333333333333333 F20
    N6010 G93
    N6020 G1 A360 F18.7855014796991
    N6030 G92 A0
    N6040 G1 X3.25 A9792.0 Z1.21875 F0.7050695328446624361749580071
    N6050 G1 A10152.0 F19.5883006882333
    N6060 G94
    N6070 G92 A9792.0
    N6080 G0 Z1.3
    N6090 G0 A9720
    N6100 G92 A0
    N6110 G0 X1.55
    N6120 (Z pass 2)
    N6130 G0 Z1.275
    N6140 G1 Z1.2666666666666666666666666666 F20
    N6150 G93
    N6160 G1 A360 F18.8472958924613
    N6170 G92 A0
    N6180 G1 X3.25 A9792.0 Z1.16250 F0.7226044056979415988859959194
    N6190 G1 A10152.0 F20.5361216892768
    N6200 G94
    N6210 G92 A9792.0
    N6220 G0 Z1.3
    N6230 G0 A9720
    N6240 G92 A0
    N6250 G0 X1.55
    N6260 (Z pass 3)
    N6270 G0 Z1.275
    N6280 G1 Z1.2624999999999999999999999999 F20
    N6290 G93
    N6300 G1 A360 F18.9094981891361
    N6310 G92 A0
    N6320 G1 X3.25 A9792.0 Z1.10625 F0.7410336652337808200651195209
    N6330 G1 A10152.0 F21.5803312666977
    N6340 G94
    N6350 G92 A9792.0
    N6360 G0 Z1.3
    N6370 G0 A9720
    N6380 G92 A0
    N6390 G0 X1.55
    N6400 (Z pass 4)
    N6410 G0 Z1.275
    N6420 G1 Z1.2583333333333333333333333332 F20
    N6430 G93
    N6440 G1 A360 F18.9721124215504
    N6450 G92 A0
    N6460 G1 X3.25 A9792.0 Z1.05000 F0.760427528519324362014284631
    N6470 G1 A10152.0 F22.7364204416993
    N6480 G94
    N6490 G92 A9792.0
    N6500 G0 Z1.3
    N6510 G0 A9720
    N6520 G92 A0
    N6530 G0 X1.55
    N6540 (Z pass 5)
    N6550 G0 Z1.275
    N6560 G1 Z1.2541666666666666666666666665 F20
    N6570 G93
    N6580 G1 A360 F19.0351426953762
    N6590 G92 A0
    N6600 G1 X3.25 A9792.0 Z0.99375 F0.7808637600399683785871671938
    N6610 G1 A10152.0 F24.0233876365125
    N6620 G94
    N6630 G92 A9792.0
    N6640 G0 Z1.3
    N6650 G0 A9720
    N6660 G92 A0
    N6670 G0 X1.55
    N6680 (Z pass 6)
    N6690 G0 Z1.275
    N6700 G1 Z1.2499999999999999999999999998 F20
    N6710 G93
    N6720 G1 A360 F19.0985931710274
    N6730 G92 A0
    N6740 G1 X3.25 A9792.0 Z0.93750 F0.8024287137194875361775964933
    N6750 G1 A10152.0 F25.4647908947033
    N6760 G94
    N6770 G92 A9792.0
    N6780 G0 Z1.3
    N6790 G0 A9720
    N6800 G92 A0
    N6810 G0 X1.55
    N6820
    N6830 (##25 Rounding end ##)
    N6840 (##31 GCode start footer code ##)
    N6850 M05 (Spindle off)
    N6860 M30 (Program end and rewind)
    N6870 (##32 GCode end footer code ##)
    N6880 (##04 End file ##)
    Mar 2003
    Shelby Township
    That code uses G93 Inverse time feedrates.
    Have you run any code from that Wizard that runs correctly?
    The wizard says it ONLY works with Mach3 3.042.029. Is that the version you are using?
    Oct 2007
    My Mach3 version is 3.042-040 and yes I have already run codes correctly with this software.
    Thank you
    I generated a square Gcode with vcarve, cutting air and the feedrate is ok
    Mar 2003
    Shelby Township
    Sorry, but I really don't know what else to look for.
    Does all code run slow now? Or just this one?
  7. #7
    Oct 2007
    I don't know because when I saw it going this slow I stop the process (speed is like comparing a turtle and a rabbit)
  8. #8
    Mar 2003
    Shelby Township
    Is the feedrate set in the Wizard? If so, try increasing it.
  9. #9
    Oct 2007
    Yes, even if I set to 15 or 1500 it’s always crawling
  10. #10
    Member Chris D's Avatar
    Apr 2005
    Looking at the program,
    N1770 G0 Z1.75
    N1790 G93
    N1810 G92 A0
    I see a Z movement on line 1780 - does that line run fine?
    If not, at a decimal point to the feedrate and see if that helps.
    If 1780 runs fine, and line 1800 runs slow, I would suspect it will take 14.147 minutes to complete. Can you time that to verify?
    Chris D
  11. #11
    Mar 2003
    Shelby Township
    No, it should take 1/14.147 minutes, or 4.2 seconds.
    It's inverse time mode.
  12. #12
    Oct 2007
    Can I delete the code G93 wherever I see it
    I found the Code of another post that I made in 2015, load it up on Mach and run perfectly, took about 3 minutes can you check it to seen if you find something different. Thank you
    N10 (##01 RÉMI OLIVIER ##)
    N30 (##03 07/25/2015 1:26:53 AM ##)
    N140 (##22 DATE: 24-07-2015 ##)
    N150 (##23 Name = X start, Value = .625, Integer = False, Positive = False, Type = NumEdit ##)
    N160 (##23 Name = X end, Value = 14.5, Integer = False, Positive = False, Type = NumEdit ##)
    N170 (##23 Name = Rough diameter, Value = 3.54, Integer = False, Positive = True, Type = NumEdit ##)
    N180 (##23 Name = Start diameter, Value = 2.53, Integer = False, Positive = True, Type = NumEdit ##)
    N190 (##23 Name = End diameter, Value = 2.53, Integer = False, Positive = True, Type = NumEdit ##)
    N200 (##23 Name = Z depth per pass, Value = .125, Integer = False, Positive = True, Type = NumEdit ##)
    N210 (##23 Name = Rapid diameter, Value = 4, Integer = False, Positive = True, Type = NumEdit ##)
    N220 (##23 Name = Stepover, Value = .5, Integer = False, Positive = True, Type = NumEdit ##)
    N230 (##23 Name = Feed rate, Value = 60, Integer = False, Positive = True, Type = NumEdit ##)
    N260 (##23 Name = Cut direction;Bidirectional;Unidirectional, Value = 1, Integer = True, Positive = True, Type = RadioGroup ##)
    N270 G0 Z2
    N280 G0 A0
    N290 G0 X0.625 Y0
    N300 (Z pass 1)
    N310 G0 Z1.77
    N320 G1 Z1.669 F20
    N330 G93
    N340 G1 A360 F5.7215677564492
    N350 G92 A0
    N360 G1 X14.5 A9990.00 Z1.669 F0.2059486573617461315405719131
    N370 G1 A10350.00 F5.7215677564492
    N380 G94
    N390 G92 A9990.00
    N400 (Z pass 2)
    N410 G1 Z1.568 F20
    N420 G93
    N430 G1 A10350.00 F6.09011261831232
    N440 G92 A9990.00
    N450 G1 X0.625 A0 Z1.568 F0.2191814311232264617611854266
    N460 G1 A360 F6.09011261831232
    N470 G94
    N480 G92 A0
    N490 (Z pass 3)
    N500 G1 Z1.467 F20
    N510 G93
    N520 G1 A360 F6.50940462543539
    N530 G92 A0
    N540 G1 X14.5 A9990.00 Z1.467 F0.2342287808614696468213212861
    N550 G1 A10350.00 F6.50940462543539
    N560 G94
    N570 G92 A9990.00
    N580 (Z pass 4)
    N590 G1 Z1.366 F20
    N600 G93
    N610 G1 A10350.00 F6.99070028222088
    N620 G92 A9990.00
    N630 G1 X0.625 A0 Z1.366 F0.2514907413468632880699965455
    N640 G1 A360 F6.99070028222088
    N650 G94
    N660 G92 A0
    N670 (Z pass 5)
    N680 G1 Z1.265 F20
    N690 G93
    N700 G1 A360 F7.54885105574207
    N710 G92 A0
    N720 G1 X14.5 A9990.00 Z1.265 F0.2714940071627127727680585424
    N730 G1 A10350.00 F7.54885105574207
    N740 G94
    N750 G92 A9990.00
    N760 G0 Z2
    N770 G0 A9720
    N780 G92 A0
    N790 G0 X0.625
    N800
    N810 (##25 Rounding end ##)
    N820 (##31 GCode start footer code ##)
    N830 M05 (Spindle off)
    N840 M30 (Program end and rewind)
    N850 (##32 GCode end footer code ##)
    N860 (##04 End file ##)
  13. #13
    Mar 2003
    Shelby Township
    What's the velocity setting for your A axis?
  14. #14
    Oct 2007
    18036 and have a gearbox with a 10/1 ratio, did you see my last post
  15. #15
    Mar 2003
    Shelby Township
    Both programs appear to run fine in demo mode.
    Changing the feedrate does indeed change the speed.
    Note that in G93 mode, the feedrates are specified in time, not actual feedrate.
    In G93 mode, a feedrate of 20 means it should take 1.2 seconds to complete the move. If the machine can't complete the move that fast, it won't go any faster. G93 feedrates much higher than that will not likely go any faster.
    The only thing I can suggest is to hand code some simple G93 moves, and see if it's working like it should be.
  16. #16
    Oct 2007
    The good news of the day, my problem is solve: Trying to get a smooth finish = (less sanding), in the wizard I was setting the stepover with a two small value .0625.
    Change it to .25 and now the gantry is moving, It’ not a rocket but it suit my needs.
    I want to thank you ever so much for trying to help me out
MACH3/FEEDRATE
MACH3/FEEDRATE
