Need Help! Modified Macros
Results 1 to 2 of 2
Thread: Modified Macros
    Oct 2008
    Default Modified Macros
    Hi Gerry
    Attached are the macros I have modified if you can review and make any changes or recommendations I would appreciate it. This is my first attempt at modifying macros.
    Bill I
    M884
    DoButton( 24 )
    Code "G53 G0 Z-2"
    'While IsMoving()
    'Wend
    DoButton( 23 )
    Code "G53 G0 Y1.25"
    'While IsMoving()
    'Wend
    DoButton(22)
    Code "G53 G0 X4.0"
    'While IsMoving()
    'Wend
    DoOemButton(1008)
    DoOemButton(1009)
    M885
    DoButton(22)
    Code "G53 G0 X4.0"
    DoOemButton(1008)
    M886
    DoButton(23)
    Code "G53 G0 Y1.25"
    DoOemButton(1009)
    M887
    DoButton(24)
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoOemButton(1010)
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Modified Macros
    M884
    DoButton(24)
    DoButton(23)
    DoButton(22)
    Code "G53 G0 X4.0 Y1.25 X-2"
    While IsMoving()
    Wend
    DoOemButton(1008)
    DoOemButton(1009)
    M885
    DoButton(22)
    Code "G53 G0 X4.0"
    While IsMoving()
    Wend
    DoOemButton(1008)
    M886
    DoButton(23)
    While IsMoving()
    Wend
    DoOemButton(1009)
    M887
    DoButton(24)
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoOemButton(1010)
    Typically, you don't want to zero the axis in the homing macro.
    Normally, if the machine loses position, you can home it to get position back, and continue.
    When you zero the axis after homing, you can no longer do this, as you then need to "find" your origin again.
    UCCNC 2017 Screenset
Modified Macros
Modified Macros
