Mach3 2010 Screen set - Page 75
Page 75 of 76 FirstFirst ... 25657273747576 LastLast
Results 1,481 to 1,500 of 1506
Thread: Mach3 2010 Screen set
  1. #1481
    Sep 2013
    Quote Originally Posted by ger21 View Post
    I'm confused. Are you using the BigTex screen, or the 2010 Screen?
    Are you using the parallel port on your old PC?
    Yes using Big Tex 3.4, parallel port, mx3660 controller
  2. #1482
    Member Pasandoelpaso's Avatar
    Aug 2019
    Default Re: Mach3 2010 Screen set
    Hello, does anyone know what is the latest version of mach3 2010?
  3. #1483
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I'll have to look when I get home. But it hasn't changed in the last 8 or so years.
    UCCNC 2017 Screenset
  4. #1484
    Aug 2019
    thanks, I have the 2010-screenset-1.1.4 version for 3 years and wanted to know if there were any changes.
    Greetings
  5. #1485
    Mar 2003
    Shelby Township
    No, that would be the latest version. There won't be any further changes.
  6. #1486
    Member Weliechiko's Avatar
    Mar 2020
    Using Mach3 and want to purchase the mach3 2010 screen set. Im using the Mach3 USB controller by Bitsensor ( Attached ), is there anbody using it with 2010 screen set, or anbody know if it works with that Board. Thanks
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-images-9-jpg
  7. #1487
    Jul 2006
    Quote Originally Posted by Weliechiko View Post
    Using Mach3 and want to purchase the mach3 2010 screen set. I'm using the Mach3 USB controller by Bitsensor ( Attached ), is there anybody using it with 2010 screen set, or anybody know if it works with that Board. Thanks
    If it works with Mach3 in it's stock form, then it should work with the screenset. The screenset is just an advanced rearrangement of the buttons effectively. There's nothing controller specific in it that I recall.
  8. #1488
    Mar 2020
    Quote Originally Posted by shorton View Post
    Thanks for the reply. The board works well with Mach3 in its stock form. I just wanted to corfirm first because on their page ( 2010 screen set developers ) they mentioned that there are some boards that do not work properly with some boards.
  9. #1489
    Activation process
    Nov 2017
    Hello,
    This Mach 2010 looks pretty good.
    Do it works with chinese xhc mk4 ethernet board?
    Regards
  10. #1490
    Jun 2010
    Any failings will be likely due to the Chinese board, not the screen set. Some of the Chinese boards are ...
    Cheers
    Roger
  11. #1491
    Jan 2018
    United Kingdom
    Quote Originally Posted by Eveb View Post
    Hello,
    Regards
    Might as well buy an AXBB-E from cncdrive. At least you know you'll get support!.
  12. #1492
    Activation process
    Nov 2017
    Quote Originally Posted by basilio View Post
    Good afternoon.
    After uninstalling everything and reinstalling, I tried the Chinese Motion Controller macros and ... WORKS !!!
    Therefore, "Mach3Version3.043.062", the latest version of the "NcUsbPod.dll" plugin and Chinese Motion Controller macros, works perfectly.
    Thank you very much
    Looks like someone solved to my question
  13. #1493
    Activation process didabad's Avatar
    Jan 2019
    Hello, I bought the 2010 screenset a few years ago and it worked fine with the parallel port, now I'm trying to upgrade to USB or Ethernet but I can't get it to work. All movements are done well with the exception of Auto Zero
    I wonder if anyone can help me, I have dealt with EC300 and NVCM6 v2.1 motion controllers
    Thanks in advance.
  14. #1494
    Sniger7700's Avatar
    Jun 2021
    Hi sir
    Did you try the 2010 software ? I’m running the same
    Board as you was in the time your posted in here.
    Best regards
    Kasper
  15. #1495
    Sniger7700's Avatar
    Jun 2021
    That’s sad. I will love a 5 axis!
  16. #1496
    Member LeifMerget's Avatar
    Dec 2022
    Hello I just bought the 2010 screenset. Just making sure it is still supported and still I will get my download. Thanksl.
  17. #1497
    Member BornConfused's Avatar
    Sep 2022
    Quote Originally Posted by LeifMerget View Post
    I came here for the same reason. Hoping to get a email soon with the download.
  18. #1498
    Dec 2012
    Afghanistan
    The last activity by ger21 was 06-12-2022 02:48 PM - you could try contacting him at cncwoodworker at comcast dot net
  19. #1499
    Sep 2022
    He actually sent me the link. Thanks for the help jim
  20. #1500
    Mar 2020
    Quote Originally Posted by Sniger7700 View Post
    Hi sir
    Best regards
    Kasper
    Hi Kasper
    I never tried it because I didnt get enough onfor aboit it. I see your Question is dated to 2022. Did you try with your one ???
