Mach3 2010 Screen set - Page 73
Page 73 of 76 FirstFirst ... 236370717273747576 LastLast
Results 1,441 to 1,460 of 1506
Thread: Mach3 2010 Screen set
  1. #1441
    Apr 2008
    Slovenia
    Default Re: Mach3 2010 Screen set
    Yes i have tried rebooting PC and restart mach 3. My Mach Version is R.3.043.062
    It must be something that i have missed. it is repeatable and it happens always when machine gets over 900mm in Y axis. Same happens if i move parking position to lets say 910mm.
    I think it is Softlimit.
    If i disable soft limit checkbox this dosent happen.
    My softlimit is set to 950mm in settings of mach 3 so I dont know why it is triggered at 900.
    Take a look at my settings is something missing.
    Mach3 2010 Screen set-img_4524-jpgMach3 2010 Screen set-img_4525-jpg
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-img_4524-jpg   Mach3 2010 Screen set-img_4525-jpg
  2. #1442
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    It might be something to do with the ESS plugin and how it handles softlimits.
    UCCNC 2017 Screenset
  3. #1443
    Apr 2008
    Slovenia
    But this only happens when running macro, if i jog machine i can jog it to 950mm like it should be.
    And if i jog it it has slow zone before reaches 950mm in macro it is sudden stop at 900mm.
    If you look picture in my previous post in 2010 screenset under tab limits section program limits, should i input some values there ?
  4. #1444
    Mar 2003
    Shelby Township
    The macros (and screenset) have nothing to do with softlimits. I'm guessing that it's the way the ESS deals with macros and softlimits, and is probably a bug in their plugins.
    I'd contact Warp9 and see what they have to say. I don't recall ever hearing about this issue in 9+ years, and thousands of users.
  5. #1445
    Apr 2008
    Slovenia
    I figured it out, it was my slave axis.
    It looks like that when running macro it checks also slave axis soft limits but when joging it is ok.
    My slave axis was set to 900 so machine always stopped if i moved touch plate out of range.
  6. #1446
    Mar 2003
    Shelby Township
    Could be because the macro is sending g-code commands. The ESS must ignore the slave softlimit setting when jogging, but not when running g-code??
  7. #1447
    Apr 2008
    Slovenia
    Now i'm using screen set without problems with movable touch plate for z and fixed touch plate for reference. Both are hard without movable parts.
    But now i'm thinking to get a 3d touch probe for XYZ and new fixed touch plate for table with movable surface. Like on photos below.
    Mach3 2010 Screen set-3d-touch-probe-pngMach3 2010 Screen set-tools-lenght-sensor-png
    Is there a way to use macro with this kind of acessories.
    Ok for 3d touch probe i would use wizard for Y and X.
    But i see problem for z axis.
    If i run initial Z zero routine probe will touch off part and then go to fixed touch plate witch is also movable in z direction so reading probably wont be accurate as i dont know what will move first 3d probe or touch sensor. Both has cca same 2N touch force.
    Any idea how to implement 3d touch probe in that combination .
    Solution would be to use fixed plate without movable parts as that would be true reference, but for safety i would rather use movable tool sensor.
  8. #1448
    Mar 2003
    Shelby Township
    I can't think if any way to use both for the initial Z zero.
  9. #1449
    Jan 2018
    United Kingdom
    Quote Originally Posted by lukahr View Post
    I use that combination of tool setter and probe all the time. You can see how I measure and correct for the error in this video https://youtu.be/LTtalZjEj4c
  10. #1450
    Default Re: Mach3 2010 Screen Set
    I recently purchased the 2010 screen set. I'm still learning my way around the different screens but so far so good! My question is about the DRO/dialogue boxes that appear on my screen that are outside of the screen set area. See the attached picture. The lower box appears on all the screens and the box on the right appears on the Tool Change screen only. I can input numbers into the boxes and they remain if I hit the "enter" key. Now to my question. What is the function of these boxes and does the entered data used by the screen set/Mach3?
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-screen-shot-01-02-20-02-51-a
  11. #1451
    Mar 2003
    Shelby Township
    They are not supposed to be seen. If you're monitor resolution is larger than the screen, then drag the window to fit the screen, hiding anything outside of the screen.
    The DRO to the right is where the fixed plate location is stored. Do NOT change the values in it.
  12. #1452
    Quote Originally Posted by ger21 View Post
    Thanks ger21. You built an awesome screen set. Unfortunately I changed the values in both boxes. Will restarting Mach3 reset the correct value?
  13. #1453
    Mar 2003
    Shelby Township
    When you run the auto zero initialize, it sets the value of the plate location. So it will be set whenever you use it.
    The box on the bottom is the feedrate, which you can change whenever you want.
  14. #1454
    Thanks.
  15. #1455
    Nov 2017
    Portugal
    Good afternoon.
    I use Mach3Version3.042.020.
    My machine is an ARFCNC 6040 card, USB, with the MKX-IV Mottion card.
    Can I buy your "Mach3 2010 Screenset"?
    Still for sale?
    Thanks.
  16. #1456
    Mar 2003
    Shelby Township
    You'll need a newer version of Mach3, as the version you have doesnt work with the 2010 screenset due to a bug with the M6 macro.
    You csn buy it from my website.
  17. #1457
    Nov 2017
    Portugal
    I cannot see page 73 of this tread.
    The screen is all blue.
    I already bought the "Mach3 2010 Screenset".
    I await the file in the email: basilio.medalha@gmail.com
    Thanks.
    Basílio Medalha
  18. #1458
    Nov 2017
    Portugal
    ger21, Thank you, received and installed.
    when I try Auto Zero, Z lowers, touches the probe, goes up, low slowly until it touches the probe again and then lowers 2cm quickly.
    This 2cm drop shouldn't happen, what am I doing wrong?
    Thank you very much.
  19. #1459
    Administrator burs's Avatar
    Apr 2019
    Germany
    Quote Originally Posted by basilio View Post
    The thread is finally fixed now. Sorry for waiting. One of your recent posts contained non-working HTML tags which destroyed the display. Therefore I had to delete it.
  20. #1460
    Nov 2017
    Portugal
    Good afternoon.
    After uninstalling everything and reinstalling, I tried the Chinese Motion Controller macros and ... WORKS !!!
    Therefore, "Mach3Version3.043.062", the latest version of the "NcUsbPod.dll" plugin and Chinese Motion Controller macros, works perfectly.
    Thank you very much
