Mach3 2010 Screen set - Page 71
Page 71 of 76 FirstFirst ... 216168697071727374 ... LastLast
Results 1,401 to 1,420 of 1506
Thread: Mach3 2010 Screen set
  1. #1401
    Member LouF's Avatar
    Sep 2011
    Default Re: Mach3 2010 Screen set
    Gerry, Okay after doing the setup without the G code loaded and it homed saying in the window on the run screen "Material Offset now Calculated in Inches" I loaded the g code I clicked run it moved back to the fixed plate and zeroed. From that postion it moved over the Material area and stopped the message popped up to start spindel so I did and clicked it and it is carving the first tool path. After carving the first tool path it stopped and moved to tool change postion and request "tool change message showed in the window". I changed tools clicked cycle start as it stateded in the window it rezeroed it started the second tool path it seems to be work fine now. It is still running the second tool path I wonder what was going on oh well it is working as before..
    As for what line it was stopping on previously I did not notice sorry.
    Thank Very Much for all your help.
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  2. #1402
    May 2010
    Is there any specific reason why federate controls were not included in Gerry's Mach 3 Aqua screen set? I saw a post in this thread that alluded to the fact Mach 3 can run rough with high overdrive settings, but this was a post from 2012, has anything changed? I haven't noticed any issues with using the overdrive.
  3. #1403
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I haven't used it in many years, but the picture on my website shows a FRO slider and DRO.
    And no, nothings changed, using FRO over 100% can potentially cause issues. I don't recall exactly, but it may be over 150% where it';s more likely to cause issues?
    UCCNC 2017 Screenset
  4. #1404
    May 2010
    Quote Originally Posted by ger21 View Post
    What is FRO slider? I don't see it in any of the screenshots.
    I see thanks. I want aware of this issue and have been using the feature all the time. I guess it's time to stop doing this and start reprogramming the parts religiously.
  5. #1405
    Mar 2003
    Shelby Township
    It's on the main Run page.
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-fro-jpg
  6. #1406
    May 2010
    Looks like I was looking at a different version.
  7. #1407
    Mar 2003
    Shelby Township
    It hasn't changed in the last 8 years....
  8. #1408
    May 2018
    Can't promise anything, as I don't know when I'll get around to using the CAM in Fusion 360.
    As Fusion is becoming more and more a standard for hobbyist maybe someone could develop a post for 2010 screenset?
    I'm willing to help if I can, it shouldn't be too hard to adapt?
  9. #1409
    Member ssw's Avatar
    Mar 2011
    Quote Originally Posted by buchnoun View Post
    Hello, I have recently started using Fusion360 CAM. I select the Mach3 post. The 2010 Screenset seems to function as expected. Are you having a particular problem?
  10. #1410
    Mar 2003
    Shelby Township
    I think he wants to eliminate the tool change at the start, to eliminate an auto zero before running the g-code.
  11. #1411
    May 2018
    not only this, I've had trouble running .tap files from fusion to mach3 ie spindle not starting or weird movements before starting path... As I don't
    want to damage my CNC I stop using it... But I found aspire quite less intuitive than fusion and would prefer to use Fusion from now on...
    Would you consider taking some time to code a post for Fusion ?
    Would be much appreciated :-)
  12. #1412
    been watching this and wondering if you can add a script to allow the screenset to talk like the one on the video.. ht*tp://yo*utu.be/MQ9XT30s-PU (please remove *) I cannot get to post the link sorry.
  13. #1413
    Jun 2011
    Just enable speech in the config???
    Allow Speech is the setting.
  14. #1414
    Mar 2003
    Shelby Township
    The video shows you how to add the speech to the macros.
    I don't think too many people would be interested in it, though.
  15. #1415
    Oct 2007
    canada
    in relation to a previous question I asked(but can't seem to find the tread?)
    changing speed of autozero...and multiple tool change
    I changed the speed of my single autozero scripts and that works as expected...but i just did a part today with multiple tool change and those are still at the default speed of 10...which scripts do i modify for that??
    thanks
  16. #1416
    Mar 2003
    Shelby Township
    M881, M889, and M6End
  17. #1417
    Oct 2007
    canada
    Found the original reply in my inbox...so am i looking for second probefeed for multiple tool autozero?? sorry not at home to check the macros...
    Find and change this line in the M881, M889, and M6End macros.
    FirstProbeFeed = 10.0 ' First probe feed @ 10 ipm
  18. #1418
    Mar 2003
    Shelby Township
    Not knowing exactly what you want, but it looks like you just want First Probe Feed.
  19. #1419
    Oct 2007
    canada
    yes i've modified my first probe feed in all of the macros....it works when i do a simple autozero...but when I use the autozero with toolchange its not going on the slower speed i specified by the first probe feed....
    Is there something else I need to modify for it to work with autozero with toolchange?? Different Macros I need to modify??
  20. #1420
    Mar 2003
    Shelby Township
    Did you modify all three macros?
