Mach3 2010 Screen set - Page 121
Page 121 of 121 FirstFirst ... 2171111118119120121
Results 1,441 to 1,446 of 1446
Thread: Mach3 2010 Screen set
  1. #1441
    Apr 2008
    Slovenia
    Default Re: Mach3 2010 Screen set
    Yes i have tried rebooting PC and restart mach 3. My Mach Version is R.3.043.062
    It must be something that i have missed. it is repeatable and it happens always when machine gets over 900mm in Y axis. Same happens if i move parking position to lets say 910mm.
    I think it is Softlimit.
    If i disable soft limit checkbox this dosent happen.
    My softlimit is set to 950mm in settings of mach 3 so I dont know why it is triggered at 900.
    Take a look at my settings is something missing.
    Mach3 2010 Screen set-img_4524-jpgMach3 2010 Screen set-img_4525-jpg
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-img_4524-jpg   Mach3 2010 Screen set-img_4525-jpg
  2. #1442
    Mar 2003
    Shelby Township
    It might be something to do with the ESS plugin and how it handles softlimits.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #1443
    Apr 2008
    Slovenia
    But this only happens when running macro, if i jog machine i can jog it to 950mm like it should be.
    And if i jog it it has slow zone before reaches 950mm in macro it is sudden stop at 900mm.
    If you look picture in my previous post in 2010 screenset under tab limits section program limits, should i input some values there ?
  4. #1444
    Mar 2003
    Shelby Township
    The macros (and screenset) have nothing to do with softlimits. I'm guessing that it's the way the ESS deals with macros and softlimits, and is probably a bug in their plugins.
    I'd contact Warp9 and see what they have to say. I don't recall ever hearing about this issue in 9+ years, and thousands of users.
  5. #1445
    Apr 2008
    Slovenia
    I figured it out, it was my slave axis.
    It looks like that when running macro it checks also slave axis soft limits but when joging it is ok.
    My slave axis was set to 900 so machine always stopped if i moved touch plate out of range.
  6. #1446
    Mar 2003
    Shelby Township
    Could be because the macro is sending g-code commands. The ESS must ignore the slave softlimit setting when jogging, but not when running g-code??
