Mach3 2010 Screen set - Page 120
Page 120 of 120 FirstFirst ... 2070110117118119120
Results 1,429 to 1,436 of 1436
Thread: Mach3 2010 Screen set
  1. #1429
    Activation process 3dmike's Avatar
    Jul 2018
    Default Re: Mach3 2010 Screen set
    many thanks for your help.
    Mike
  2. #1430
    Jul 2017
    I have the 2010 screenset and it is working great. Love all the features especially the tool change!!
    I am considering getting one of the drewtronics probes ( normally closed ) and a tool setter ( normally closed ).
    I can not wrap my head around what the process would be to use the probe for setting Z with the tool.
    Right now I start the program with the first tool in the spindle and it sets Z with the tool against the touch block ( normally open ), sets it again with the remote tool plate, and then starts cutting with the first tool. But I can't use the touch block for the first tool if I change the Mach3 setting to support normally closed.
    The one thing I could think of would be to have the probe in the spindle, start the program, let it probe Z against the work surface, go to the remote tool setter, probe Z, then have the program do a tool change to the first tool and it will then set Z for the tool off the tool setter, and then start cutting.
    I'm not sure the probes would be worth the effort then at least until I could get a real tool changing spindle.
    Any other ideas or suggestions?
    Thanks!!
  3. #1431
    Jul 2014
    Hi Gerry, been using your screenset since I started. Lately the screen will not open to cover the entire screen, no trouble really just irritating. Can you help? I am sure it should be a simple fix I am just missing.Mach3 2010 Screen set-mach3-screen-png-png
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-mach3-screen-png-png
  4. #1432
    Jun 2010
    it's Windows. Just grab the bottom right hand corner and drag it out. Then save settings.
    Cheers
    Roger
  5. #1433
    Mar 2003
    Shelby Township
    You don't have ti save any settings.
    Just drag the window to fit, and close and restart Mach3.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  6. #1434
    Jul 2014
    I drag the bottom right corner to the screen size I prefer every time. Yet it reverts back to that size once I restart mach3.
  7. #1435
    Mar 2003
    Shelby Township
    Auto Screen Enlarge is off?
    The only thing I can think of would be a bad .xml. Try replacing it with a backup.
    Mine always stays the size that i drag it to, and I've never heard of this from anyone else.
  8. #1436
    Jul 2014
    Sorry for being a noob, but how do I do that?
