Mach3 2010 Screen set - Page 119
Page 119 of 119 FirstFirst ... 1969109116117118119
Results 1,417 to 1,424 of 1424
Thread: Mach3 2010 Screen set
  1. #1417
    Oct 2007
    canada
    Default Re: Mach3 2010 Screen set
    Found the original reply in my inbox...so am i looking for second probefeed for multiple tool autozero?? sorry not at home to check the macros...
    Find and change this line in the M881, M889, and M6End macros.
    FirstProbeFeed = 10.0 ' First probe feed @ 10 ipm
  2. #1418
    Mar 2003
    Not knowing exactly what you want, but it looks like you just want First Probe Feed.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #1419
    Oct 2007
    canada
    yes i've modified my first probe feed in all of the macros....it works when i do a simple autozero...but when I use the autozero with toolchange its not going on the slower speed i specified by the first probe feed....
    Is there something else I need to modify for it to work with autozero with toolchange?? Different Macros I need to modify??
  4. #1420
    Mar 2003
    Did you modify all three macros?
  5. #1421
    Oct 2007
    canada
    yes modified all three...that should work for the autozero with toolchange too then?
    I'll have to test again...but it sure did seem faster than then 6ipm i set...
  6. #1422
    Mar 2003
    Yes, M6end handles the auto zero after the tool change.
  7. #1423
    Jul 2011
    Hi Gerry,
    I Purchased your 2010 screenset back in 2013 but never received any updates.
    If there is any can you please send them to me?
    Also have a problem now. I Had to go overseas for about 2 years now i'm back and started my CNC to see if everything is still working but no movement from the motors.
    Looking at the DROs I get nothing. What could be wrong? The machine was working perfect before.
    Gus
  8. #1424
    Mar 2003
    About a million different things.
    If the DRO's aren't working, make sure that mach3 is not in Reset, and that the motors are configured properly.
