Mach3 2010 Screen set - Page 118
Page 118 of 119 FirstFirst ... 1868108115116117118119 LastLast
Results 1,405 to 1,416 of 1426
Thread: Mach3 2010 Screen set
  1. #1405
    Mar 2003
    Default Re: Mach3 2010 Screen set
    What is FRO slider? I don't see it in any of the screenshots.
    It's on the main Run page.
    Attached Thumbnails Attached Thumbnails Mach3 2010 Screen set-fro-jpg
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #1406
    May 2010
    Looks like I was looking at a different version.
  3. #1407
    Mar 2003
    It hasn't changed in the last 8 years....
  4. #1408
    May 2018
    Quote Originally Posted by ger21 View Post
    Can't promise anything, as I don't know when I'll get around to using the CAM in Fusion 360.
    As Fusion is becoming more and more a standard for hobbyist maybe someone could develop a post for 2010 screenset?
    I'm willing to help if I can, it shouldn't be too hard to adapt?
  5. #1409
    Registered ssw's Avatar
    Mar 2011
    Quote Originally Posted by buchnoun View Post
    Hello, I have recently started using Fusion360 CAM. I select the Mach3 post. The 2010 Screenset seems to function as expected. Are you having a particular problem?
  6. #1410
    Mar 2003
    I think he wants to eliminate the tool change at the start, to eliminate an auto zero before running the g-code.
  7. #1411
    May 2018
    not only this, I've had trouble running .tap files from fusion to mach3 ie spindle not starting or weird movements before starting path... As I don't
    want to damage my CNC I stop using it... But I found aspire quite less intuitive than fusion and would prefer to use Fusion from now on...
    Would you consider taking some time to code a post for Fusion ?
    Would be much appreciated :-)
  8. #1412
    Jul 2014
    been watching this and wondering if you can add a script to allow the screenset to talk like the one on the video.. ht*tp://yo*utu.be/MQ9XT30s-PU (please remove *) I cannot get to post the link sorry.
  9. #1413
    Jun 2011
    Just enable speech in the config???
    Allow Speech is the setting.
  10. #1414
    Mar 2003
    The video shows you how to add the speech to the macros.
    I don't think too many people would be interested in it, though.
  11. #1415
    Oct 2007
    canada
    in relation to a previous question I asked(but can't seem to find the tread?)
    changing speed of autozero...and multiple tool change
    I changed the speed of my single autozero scripts and that works as expected...but i just did a part today with multiple tool change and those are still at the default speed of 10...which scripts do i modify for that??
    thanks
  12. #1416
    Mar 2003
    M881, M889, and M6End
