Quote Originally Posted by Bildozer View Post
I work at a facility that specializes in carbon fiber machining (we occasionally cut fiberglass as well), and I have to say, we avoid cutting dry at all costs.
If you have the option to make a flood coolant system instead of a vacuum, I highly recommend it.
If you do it right, it can costs about the same and you will have better results in terms of health safety with flood coolant vs. vacuum.
Just my .2c
What size micron filters do you use to filter the fiberglass from the coolant?
