- R991H questions
R991H questions
All right here is an overview of what we have so far an old freggin mill that is in awsome shape. However the controller is an old tape POS that is about the size of a fridge and still uses tape. anyway the rutex r991h servo drives will work with the servo's on mill. so the question now is which of the following will work and what are the benefits/downfalls of each
mach3->rutex drives->mill servo's
mach4->grex->rutex drives->mill servo's
after reading the pdf's for the rutex drives i'm pretty sure that both of these setups will work but i'm curious as to the benefits and downfalls of each.
thanks
- R991H questions
- You may not post replies
- You may not edit your posts
Forum Rules
