MDF board protect table surface (1)
Results 1 to 1 of 1
Thread: MDF board protect table surface (1)
    Member Roctech-Lillian's Avatar
    Apr 2019
    Default MDF board protect table surface (1)
    Q . This could be a silly question: When we use MDF board under the working panel, I understood that we have to sand the board when used for the first time to make the vacuum pass through. Is this right? How can we do it?
    A . Yes, you are right. When use this machine, milling to a level, put the MDF board on the table and fixed it, then put your panel on the MDF board, turn on the vacuum pump, can hold your panel through MDF board. (like the pictures in attachment)
    MDF board protect table surface (1)-c28c73d545cfc8695d2dca647776fef-jpg
    Attached Thumbnails Attached Thumbnails MDF board protect table surface (1)-c28c73d545cfc8695d2dca647776fef-jpg
