*With heavy steel structure, this machine is specially designed for curve surface cabinet, doors and indoor decoration. and also for some mold prcessing.
*Can be used for mass processing with Vacuum holding way and dust collector.
*We use top quality components for the machine, such as HSD 9KW ATC spindle, and the spindle can rotate
+/-90 degree, Yaskawa Servo motors, Becker Vacuum pump, Hiwin linear, Syntec control
system and so on, to keep the machine in the best condition even after working for many years.
*Roctech Abby: email cnc07@roc-tech.com
