Newbie 11YO board, no instructions
Results 1 to 3 of 3
Thread: 11YO board, no instructions
    Jul 2009
    Default 11YO board, no instructions
    I bought a 4-axis CNC motor kit from Rockcliff in 2009, and promptly put it on a shelf and forgot about it.
    I always meant to get around to doing something with it, and now is that time. 11 years later.
    I'm going to put a 2'x4' table together out of aluminum extrusion and connectors, but the problem I have is that I can't find the instructions that came with the board.
    I'll make a followup post with a labelled picture and the information I'd like.
    Jul 2009
    Default Re: 11YO board, no instructions
    1) POWER INPUT - Obviously positive and negative, but how much?
    2) WIRE CONNECTOR BLOCK - Not sure of these at all. I imagine that some are for Estop and limit switch connections.
    LPT1 GND
    1
    10
    11
    12
    13
    14
    15
    16
    17
    X
    Y
    Z
    A
    COM
    3) XYZA ENABLE - I'm planning to run this with A mirroring X. Assuming I leave all the jumpers on to keep them enabled. Duh.
    4) A-, A+, B+, A- connectors and MS1, MS2 jumpers - I imagine these are connected to the NEMA23 motors.
    5) X_CUR, Y_CUR, Z_CUR, A_CUR pots - Not sure what these are for.
    11YO board, no instructions-2020-05-02-12-36-15-jpg
    The kit came with this motor driver board
    4x NEMA23 270oz/in hybrid motors
    6' parallel cable
    24V DC @ 6.5A power supply selectable 120/240V AC
    I know that there are a few really simple solutions out there using Arduino UNO boards with CNC hats, and I might eventually try that if I can't get this to work.
    I already have this, so I'd like to try to use it.
    Attached Thumbnails Attached Thumbnails 11YO board, no instructions-2020-05-02-12-36-15-jpg
    Jan 2008
    Just saw this, I have the manual as a PDF if you still need it.
