I have a drawing ,all machined surfaces just to clean up and finish cast iron 60 finish
Need to have a fly wheel turned on outside diameter and rim edges two ( ea. ) # 60 surface finish, fly wheel approximate 11 inches casting ,bore HOLE FOR SLIDING FIT FOR .625 SHAFT also put in 1/4 20 setscrew hole for grub screw 15 degree angle thread not necessary.
The set screw will be centered on the hub either side does not matter , all sizes are as they just clean up to remove casting flash ,clean up center hub, face both end's no clean up on the diameters of center hub.
The job has been filled .
Thank you for to those who replied
