Cutting carbon-fiber composites is difficult for CNC routers; the best way to do it is with an abrasive water-jet cutter. Try these guys: https://lmats.com.au/services/mechan...et-prototyping
I have a carbon fiber sheet of 4mm thickness. I have the DXF files to be cut out of. (Attached)
I'd be more than happy to travel to your location to get my parts cut out.
I'm getting desperate.
Thanks in advance,
Nikhil Govula
- New Machine Build- fiber laser cutting machine cut 8mm carbon steel
- Newbie- DIY machine or Shopbot for watercutting or flood table possible to cut Carbon Fiber?
- Need Help!- How to best machine carbon fiber???
- Where to find Detail Info of a 3D weaving carbon fiber machine ?
- Tools for machining solid carbon (not carbon fiber)-more posted
Andrew Werby
https://computersculpture.com/
I have a really well priced option that I could do out of 3mm carbon if that works. Super high quality also.
