RFQ - Small Nylon 6/6 Cupseals for CNC Mill
Results 1 to 4 of 4
Thread: RFQ - Small Nylon 6/6 Cupseals for CNC Mill
    Default RFQ - Small Nylon 6/6 Cupseals for CNC Mill
    Hello,
    I am looking to have 100 parts as attached machined from Nylon 6/6.
    These are cupseals for a pressure vessel the center hole needs to be press fit on a shaft so that tolerance is fairly critical for a sealed crush fit.
    My thought would be these would be best to be machined from sheet stock but of course I am open to any suggestions as long as we can hit the tolerance I need.
    I am open to suggestions for different kinds of nylon if it is easier, as long as the durometer is the same.
    I have an inventor file I can post that as a different format if someone is interested, the site just says it is invalid when I try to upload the native file.
    Regards
    Andrew
    Attached Files Attached Files
    Default Re: RFQ - Small Nylon 6/6 Cupseals for CNC Mill
    Where would these be shipped?
    Shipped to New Jersey
    To All,
    The order has been filled
    Thank you for your inquires.
    Andrew
