Hi Shanghyd,
My father owns a factory for gear manufacturing factory located in Taiwan for over thirty years.
If you still need help, send me the sample or photo.
I have a Birmingham NSL 19X60 lathe. Previous owner crashed it and tore up one of the change gears. I'll give overall details and can provide more specific details where needed.
I'm not a gear expert so I'll post what I think I figured out.
132 teeth
total width of gear 19.05mm
Pitch circle diameter 198mm
outside diameter 201mm
MOD 1.5mm
Total depth of tooth 3.375mm
Center bore can be whatever you need to cut the teeth with. I can finish machining the gear. Just need the teeth done right.
I can provide pictures of the old gear.
- Need Help!- Change gear help
- Need Help!- Norgren Gear Change Solenoid - Gear Change Issues
- Problem- gear change
- Build Thread- Gear change pgm? How to handle
- Need Help!- Having trouble with vf2 gear change
Hi Shanghyd,
For commuters, a hybrid is a good first bike. Cheap, dependable, and simple to ride, with a wide gear range and rack and fender bosses. In addition, the geometry provides a good balance of speed, agility, visibility, and stability.
I'd go with an entry-level hybrid from a reputable brand. That will be a good-looking bike that will do the job. If you buy it new, it will cost between $300 and $400 check at dirtbikeadvisor.com. However, there is a healthy used market for them, and newish, lightly-used hybrids can usually be found for $150-250. Instead of getting Amazon crap, I'd go that route.
