Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
Results 1 to 4 of 4
Thread: Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
    Apr 2014
    Default Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
    As per the title.
    RFQ for Laser Cutting of small parts from Mild Steel, majority being 4mm, with 1 item being 2mm.
    RFQ preference is for the UK, EU or China as from experience the shipping cost from the USA will be too high including for duty...... but you are welcome to quote if you really want tofrom experiance I suspect that the cost will be prohibitive though.
    All of the quantities are shown in the file name as are the material thicknesses
    All files are within the attached zipped folder.
    Shipping will be to the United Kingdom, post code Liverpool, L1 1DE for the purposes of quotation {the correct and full address will be given at time of order}
    The parts could be 2.5D milled + drilled but I expect that the cost would be higher than high speed laser.
    Attached Files Attached Files
    Member konwey's Avatar
    May 2017
    China
    Default Re: Request for Quote - Laser Cutting Mild Steel 2mm + 4mm UK EU or China
    I can't open this drawing here.
    Can you send it to me by mail?
    Kon@plusminusthree.com
    Thanks?
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
    hi, if you still have any need please send darwing and detail by email
    info@ebi-part.com
    Registered sunshineCNC's Avatar
    Mar 2018
    SHEN ZHEN
    Hi ,we are a CNC factory located in Shenzhen China,please could you email the 3D&2D to sunny051ja@163.com,I'll quote to you ASAP.
