Need A Quote Simple Aluminum Bars with Rounded Corners
Results 1 to 7 of 7
Thread: Simple Aluminum Bars with Rounded Corners
    Feb 2010
    Default Simple Aluminum Bars with Rounded Corners
    6061 Aluminun Bar
    0.75" x 0.125" X 14"
    Bar may be extruded with rounded corners on sides, or not, the side rounding is preferred, but not important.
    Ends rounded at 0.045 radius on all 4 edges. No sharp edges on whole part.
    I get a good finish on these using dish scrubbing pads, and would like a finish like that.
    Tolerance 4 thou.
    This is for a patent pending medical device. Very much like an Orthopedic. The final product is worn on the body presses against fabric, so I want to avoid damage from sharp corners.
    Quantities to quote:
    100
    1000
    5000
    Member cooperjm's Avatar
    Sep 2009
    Default Re: Simple Aluminum Bars with Rounded Corners
    Do you have a drawing of the item? You can send it to g28Machining@gmail.com.
    Sent from my SM-G955U using Tapatalk
    *Registered User* Jbruno's Avatar
    Dec 2018
    PM sent...
    Jimmy Bruno
    www.stonewellbodies.com
    Mar 2008
    PM sent
    Thank You
    Matthew Schindler
    Micro Shaped
    Matt@MicroShaped.com
    Member deanrach's Avatar
    Jun 2005
    Pm sent ...
    Sent from my SM-J320R4 using Tapatalk
    Feb 2010
    I have some changes to my quote.
    This is not a high precision part. When in use, all sides will be touching foam padding, or fabric, so I just need the corners rounded as to not tear into the fabric. 0.045 radius, but 0.04 or 0.05 is ok too. Round all edges, and corners.
    Simple Aluminum Bars with Rounded Corners-roundedcorners-jpg
    Quantities, lengths vary.
    100 pieces:
    20, 11"
    20, 12"
    20, 13"
    20, 14"
    20, 15"
    1000 pieces:
    200, 11"
    200, 12"
    200, 13"
    200, 14"
    200, 15"
    10,000 pieces:
    2000, 11"
    2000, 12"
    2000, 13"
    2000, 14"
    2000, 15"
  7. #7
    Member CROSSHATCH's Avatar
    Sep 2006
    Quote Originally Posted by bmurph View Post
    100 pieces:
    20, 11"
    20, 12"
    20, 13"
    20, 14"
    20, 15"
    1000 pieces:
    200, 11"
    200, 12"
    200, 13"
    200, 14"
    200, 15"
    10,000 pieces:
    2000, 11"
    2000, 12"
    2000, 13"
    2000, 14"
    2000, 15"
    Pm'd you, if you could just e-mail me with the address I provided, I'll respond with my quote!
    Kind Regards,
    Jason
