Need A Quote 30'x10' plate with countor and holes 20 peices located in nh usa
Results 1 to 3 of 3
Thread: 30'x10' plate with countor and holes 20 peices located in nh usa
    ruffiansnow's Avatar
    Oct 2018
    chester
    Default 30'x10' plate with countor and holes 20 peices located in nh usa
    please see attached file, reply to ruffiansnowbikes@gmail.com
    i can send cad file in any format you want, 16g chromoly steel,can be cut using plasma, cnc, or water jet. will reorder often.also 60 aluminum parts also if interested. must be in the united states
    Attached Files Attached Files
    Oct 2018
    chester
    Default Re: 30'x10' plate with countor and holes 20 peices located in nh usa
    bump
    Dec 2004
    Hi Ruffian,
    Your title is in feet and your drawing is in inches, please clarify.
    Mike
