- Precision Drilling RFQ's wanted
I am looking for any and all precision drilling RFQ's on small parts that are under 13"x16".
These are normally any drilled hole that have position and/or runout tolerances under 0.003". I will precision drill any hole(s) you need that are 1/2" and under. I can also apply finish reaming to closer than that. I can also do precision countersinking to 100 degree for aircraft rivets. If you need holes larger than 1/2" (0.500") up to 1", can do that as well.
I will drill these materials:
1018, 4340, 4130, 4140 Steel
2024-T3, 7075-T6, 6061-T6 Aluminums (Kaiser & ALCOA)
Nylon 6/6 (any type including wear resistant grades)
Some others... just ask.
Supply print as DXF and/or DWG. Can convert others. PDF prints are ok too.
If you supply line drawing or sketch I can also CAD for you.
Re: Precision Drilling RFQ's wanted
We are still taking drilling jobs. Especially on parts that are smaller than 6" x 12" x 16" (152.4mm x 304.8mm x 406.4mm). No exotics. mostly Aluminum and Steel.
We prefer parts that are 1018 and 6061..
Private message me here if you have need for accurately located holes and accurate diameters.
Banned
There's such an emphasis on returning cash and paying down debt in energy. There's a surplus of rigs and I can't imagine anyone buying them. It's a tough situation. If you like energy, better to buy an upstream producer with a good balance sheet.
Tutuapp 9Apps Showbox
- You may not post replies
- You may not edit your posts
Forum Rules
