- New Machine Build- PM940 5 axis build
PM940 5 axis build
I am working on a 5 axis PM940 based around a 12" bridgeport rotary table for the c axis and some wheel hub bearings for the a axis. The large Z travel of the 940 and wide table makes this setup feasible. I am using fusion 360 and linuxcnc. I am wondering whether linuxcnc kinematics support dynamic work offset. Still reading through the code. I've made a vr180 video of the hardware so far and am curious about your thoughts: https://youtu.be/4_pkakOSfuM
I watched your video. are successful
- You may not post replies
- You may not edit your posts
Forum Rules
