In regard to the tube, that is shady but a common practice among ebay sellers to quote a peak power rating versus the true usable rating (use without quick shortening of the life of the tube). People were able to get ebay to go to bat for them when sellers were selling 60 watt tubes but they blatantly tested as 45-50w. Your seller is giving himself a way to try wiggle out of things with his double-speak. I don't know if you would be able win. Here is the official RECI page for your tube:
http://www.recilaser.com/en/index.ph...&catid=7&id=66
It sounds like your power supply is underpowered for your tube. If you are only able to achieve 21 mA at full power, something is not right and you are not going to be able to access the full power of your tube.
Your RECI tube should have a bar code on it. You ought to scan it to see if they gave you a real RECI or a fake. Read this page fully:
Anti-counterfeit Label - Beijing Laser Technology Co., Ltd.
- - - Updated - - -
http://www.recilaser.com/en/index.php?m=&c=Index&a=show&catid=7&id=66
It sounds like your power supply is under-powered for your tube. If you are only able to achieve 21 mA at full power, something is not right and you are not going to be able to access the full power of your tube.
http://www.recilaser.com/en/index.php?m=&c=Index&a=show&catid=13&id=34
