Need Help! Attaching Rotary to 2017 RedSail Laser
Results 1 to 3 of 3
Thread: Attaching Rotary to 2017 RedSail Laser
    Dec 2014
    Default Attaching Rotary to 2017 RedSail Laser
    Just bought my second Redsail Laser, 100w 2017 model and wanting to put a Rotary attachment on it. I’ve been told there isn’t a port for this so what’s involved with getting this happening? It’s running RDWorks.
    thanks in advance
    Apr 2018
    Default Re: Attaching Rotary to 2017 RedSail Laser
    Hi Ken,
    I'm in the middle of adding a rotary to my Redsail CNC router RS6090.
    There is a place to add the wiring if you open the cabinet. If you look on the circuit board to which the three drives connect you will
    see X Y Z...and yes a blank C axis.
    You need to buy a stepper drive. and the rotary axis.
    I also bought an aviation GX type connector to go through the cabinet wall.
    Your laser may already have a knockout on it.
    I looked at those before I went with the router, as I do mostly 3D work.
    What software did it come with for the computer to feed the machine?
    jebsmith2112's Avatar
    Aug 2018
    I have heard that you can't add a rotary axis to these controllers, and you have to swap out the y axis. Maybe I am wrong.
