Hi Ken,S4 is 100w to 130w ,and the the maximum power is 130W,and S4 1400mm,not 1650mm.
Finally my X900 Red Sails Laser has arrived.
Here is the label on the CO2 Tube, my concern is that it says 100W, and I was told it was 130W.
I googled the Length and it says the RECI Tubes 100W are 1400mm Long ( which it is ) while a 130W is 1650mm Wide.
The X900 wouldn't fit the 1650mm Tube so I feel the seller hasn't been honest and charged me extra but given me a less powerful Tube? Am I correct?
That's a Strange way of explaining wattage, If I buy a 100w Light Bulb, its 100w and can't glow brighter.
so if I set the power at 50% the 100w would mean there is still another 50% available power, or is there still 80% Power left based on the 130w, or another way at looking at it, if I set the power on 80% ( which isn't the best for a 100w Tube ) is it 80% of the 100w or 80% of the 130w?
Ken did you get this resolved?
Hello Anwar, I have just come back from 2 weeks in Taiwan and before I left And while setting the Focus and mirrors I noticed a sparking of the Laser Tube through the Perspex cover. I asked the question on this forum if anyone knew why but no one came back with a comment while I was away. I have googled it and a few sites say that it means the Laser Tube needs to be replaced?? Hoping you can come back with another reason as all its done is around twentry 5cm squares while I get everything adjusted so it's done less then 20min.
Hi Ken ,
You mean the laser tube with fire?And i am not always on here so if possible you can email me about anything:sales09@redsailcutters.com
Thanks.
