alternative to bCNC
Results 1 to 8 of 8
Thread: alternative to bCNC
    Default alternative to bCNC
    Hello,
    I started with bCNC, but it's really buggy
    can someone point me to an easy to use soft to mill pcb's
    thanks
    Member dharmic's Avatar
    May 2015
    Default Re: alternative to bCNC
    flatcam's pretty good for converting gerbers into gcode.
    Quote Originally Posted by dharmic View Post
    ok but does it RUN the cnc ?
    May 2015
    Ah, sorry, missed that bit. It does not.
    Flatcam to create the gcode and Mach3 to run it, maybe?
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    What is buggy in bCNC?
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    I scan the surface, then I start the cnc process, the bit breaks off all the time (just the tiniest bit of it)
    so I rescan, reengrave, but loose in precision and top/bottom layer never prints the same depth
    so far I ruined tons of copper, money and patience with bCNC
    I use 20° 0.1mm bits
  7. #7
    Apr 2005
    Vanuatu
    Are you using correct procedure for autoleveling?
    check this: https://github.com/vlachoudis/bCNC/wiki/AutoLevel
  8. #8
    Quote Originally Posted by ZASto View Post
    thanks I'll check it out
    I lowered the feed rate in the mean time, seems to help a bit
alternative to bCNC
alternative to bCNC
