- Need Help!- Trigger for _OUTPT=MACRO
I have some custom macros inside CNC machine controller that I have to use it for positioning 4th and 5th axis. For this I had use the _output macro to edit the G code which is trigger by a tool change. The problem appears when I use the same tool for 2 consecutive sequences because the macro is outputted only once for the first sequence and not for the second one also. Can somebody help me to choose another trigger, one that is not dependent of tool change?
- You may not post replies
- You may not edit your posts
Forum Rules
