Newbie Roland Modela MDX-3/Picza PIX-3 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Roland Modela MDX-3/Picza PIX-3
  1. #21
    Mar 2011
    UK
    Default Re: Roland Modela MDX-3/Picza PIX-3
    Quote Originally Posted by shifty-99 View Post
    I've acquired an MDX-3 and have "bodged" together a powersupply for it and have managed to get it connected up, but I cannot get Vpanel etc. to see it.
    I need the drivers, however Roland have obviously discontinued support for this model now, so there aren't any available for Windows 10. Does anyone know of any updated drivers, a driver for another machine that will do the same job, or any other way to get it to work?
    I'm still fairly new to all this so forgive my "newbie" attitude.
    Any help will be greatly appreciated.
    Many thanks
    -Zack
    Hello Zack,
    I don't have my MDX-3 any more so I can't play with it to be of certain help, but here are a few suggestions:
    Windows 10 is quite good at running old software, just do all installs and run the software 'as an administrator'
    Right click the programs and set compatibility to something old, e.g. Windows 98 or ME as a start.
    If you have a parallel port built-in then it ought to work OK, USB - Parallel (or USB - serial for that matter!) adaptors are not all as compatible as they would like to be.
    Finally try and find an old PC which runs an old version of Windows and use that. I suspect this would be the most reliable solution.
    Sorry I can't be of more help.
    Good luck,
    David
  2. #22
    Nov 2015
    hi dear
    I am also looking for Dr Picza PIX 3 software
  3. #23
    Nov 2015
    Default Re: Modela Pixza 3
    hi dear
    my eamil : n.mziri@gmail.com
    thank you
