- Need Help!- Master XY38 setting changing
Hi
I have ad this cutter for a while, bought it used and has always worked fine. Recently when I turn it on the pressure is up over 500. Sometimes when go to adjust it it just drops to zero. I reset it and then the speed changes set the speed and the pressure changes. Anyone know if it can be fixed? and how? Thanks
Rob
- You may not post replies
- You may not edit your posts
Forum Rules
