- Flatbed CNC UV ink printer with rotary
Hi everyone, I just signed up and in need of some help to buy or build a machine. Its basically a bottle printer but instead of a bottle printer being the usual size about 10" long I need to do a bottle 28" long.
I need something that I can mount a UV inkjet print head onto that will print onto 28" round wooden rods (9mm diameter) on a rotary attachment.
Either singles or multiples of 10 at a time (ideally 10). The print length will be no longer than 12"
I have been thinking of using the X, Y and Z axis' from a laser engraver. Ideally the rotary (Z) would need to have multiple wooden rods that all rotate at the same time and the Y axis would move to the next once the previous one has been printed. The print head will need setting up so it can be cleaned properly, not sure what software can be used or modified.
Any suggestions, links or help would be greatly appreciated
- You may not post replies
- You may not edit your posts
Forum Rules
