- Newbie- CNC Size for Pen Plotter
I am trying to build a CNC pen plotter for my project. Due to the cost limitation, i will use NEMA 17 stepper motor. Is 1800mm x 1100mm working area reasonable with these steppers or should i go for a different size. Whether the speed and precision of this motor is good for this working area size?
- You may not post replies
- You may not edit your posts
Forum Rules
