Need Help! Master Desay xy380 (12 years old)
Results 1 to 2 of 2
Thread: Master Desay xy380 (12 years old)
    Oct 2007
    canada
    Exclamation Master Desay xy380 (12 years old)
    Hi I have a master desay xy380, its about 12years old, bought it in Burlington, ON, Desay Canada Inc.
    Its worked well enough for what i need and wasn't until recently when i need to print some decal sheets on my inkjet and them plot them to cut them out did I notice that its actually out about an 1/8" over a 12" distance in the left/right cutting...(haven't checked in and out yet)
    The manual I have mentions nothing about calibration of the unit....anyone know how to calibrate these ones???
    thx
    Oct 2007
    canada
    Default Re: Master Desay xy380 (12 years old)
    posting this here for future knowledge...got it figured out now.
    Software adjustment in WinPCSign
    You can calibrate in WinPCSIGN
    Open Plotter code, then go to Commande and open Other commande
    Then change the X Axis and Y Axis resolution value
    Deafault value 40.0
    I went with this formula as I described below and measured with my digital caliper in both axis cutting a 5" x 5" sqaure, so both axis were different values, it worked out now using this formula ...also realized X axis on my machine is in/out and Y axis is side to side.
    (value i want) * (current software setting) = A
    (A / (actual distance measured on machine) = final software setting value
