- Need Help!- Master Desay xy 380 calibration? how to ?
Hi, I have an older Master xy 380 and need to figure out how to calibrate moves from the software to cutter.
As an example, this weekend I printed out some stickers on my inkjet printer and wanted to cut around them with my plotter..but for some reason nothing seemed to line up correctly...then i did some measuring ...what was supposed to cut in X direction is out about 1/8" over a 6" travel....
I dont see any way of being able to calibrate movements? the software that came with it was WinPCSign software, this was over ten ago at least and the Desay distributor is no longer around in Brampton, where i got it.
Does anyone have any input on how to calibrate??
- You may not post replies
- You may not edit your posts
Forum Rules
