CNC Vinyl cutting
Results 1 to 10 of 10
Thread: CNC Vinyl cutting
    Oct 2003
    Auburn, Washington
    Default CNC Vinyl cutting
    I used to operate plotters at the sign shop I worked at long ago. I'd use Casmate and Graphicad back in the day. Anyway, the plotters used spring loaded adjustable swivel knives. The plotters overcut adjoining lines to account for the blade width so the cuts were connected.
    I was wondering if anyone has tried cutting vinyl this way with their home made CNC machine and if they've had to account for this in their G code.
    How did the vinyl turn out? How small can you go with fonts?
    Darren
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Here's a link of a vinyl cutter.
    http://www.cuttingedgecnc.com/vinyl.htm
    Hager
    Apr 2008
    America
    I have been working on a vinyl cutter tool. I did a bit of testing on Friday and after a couple of false starts I think its ready:
    [nomedia="http://www.youtube.com/watch?v=GcJB2Bf4Qyc"]YouTube - Vinyl-cutting-1.wmv[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=8nUfqMjmRvE"]YouTube - Vinyl-cutting-2.wmv[/nomedia]
    Not sure about small fonts but it did manage the antennae on a butterfly sticker. The antennae are about 2 inches long but maybe a 32nd wide at the slimmest. That bodes quite well for small fonts.
    Bob
    Member robe_uk's Avatar
    Apr 2005
    Northern Ireland
    I seen these holders on Ebay so would make implementing on a cnc router easy enough I think
    I'll get it finished sometime after I start it.....
    Apr 2009
    Quote Originally Posted by Darren_T View Post
    Darren
    LOL I STILL work with CasMate! And I still find it easier than anything I ever used. Surprisingly it runs in Windows 7, not bad for 20 year old software!
    Registered neurofen's Avatar
    Dec 2010
    uk
    i bought this vinyl cutting head about 3 years ago, It's made by Roland.
    The 'blades' are held in place with a tiny bearing ring and spring mounted. Height is adjustable by the brass ring on the outside.
    I'd tried some cheaper ones off ebay but this worked a lot better but was a bit more expensive.
    It didnt come with the jubilee clip(probably obviously) or the metal its attached to;a friend made made that, but the assembly worked well to.
    The cnc i had at the time was a tiny kit job and the stepper drivers didnt allow for curves, so everything i cut was made up of straight lines, BUT, it was able to cut fairly quickly very thin parallel lines: with the right vinyl, 1mm apart or maybe less, i didnt measure.
    It depends a lot on what youre cutting. I generalyl didnt cut to small cause it took to long to weed it *
    I was going to hook this up in the week but havent got around to it what with work and that, got rolls of vinyl lying about, will post a few vids of it cutting curves if its of interest.
    Attached Thumbnails Attached Thumbnails CNC Vinyl cutting-photo0609-jpg   CNC Vinyl cutting-photo0610-jpg   CNC Vinyl cutting-photo0611-jpg   CNC Vinyl cutting-photo0612-jpg
  7. #7
    Apr 2008
    America
    Neurofen,
    How much was the Roland cutting head?
    Cheers,
    Bob.
  8. #8
    Oct 2010
    These guy's make a cutter for your CNC
    cnc 1/4" knife holder
  9. #9
    Dec 2010
    uk
    Quote Originally Posted by Bob Shaw View Post
    Neurofen,
    Cheers,
    Bob.
    approx. £40 including delivery and 5 blades.
  10. #10
    Registered slowdigits2's Avatar
    Nov 2014
    canada
    Default Re: CNC Vinyl cutting
    I have cut a lot of vinyl using the widget works cutter works awesome
    Attached Thumbnails Attached Thumbnails CNC Vinyl cutting-20170928_172922-jpg
CNC Vinyl cutting
CNC Vinyl cutting
CNC Vinyl cutting
