- Custom G code
Custom G code
I've got a cnc lathe that doesn't want to work with the regular G84/G88 for tapping. Instead it requires G84.2/G88.2.
Does anyone know how to fix so that the postprocessor adds the ".2"?
Here is the code for the tapping:
case "tapping":
if (gPlaneModal.getCurrent() == 19) { // radial
if (tool.type == TOOL_TAP_LEFT_HAND) {
gCycleTapping = 196;
} else {
gCycleTapping = 88;
} else { // axial
gCycleTapping = machineState.axialCenterDrilling ? 184 : 186;
} else {
gCycleTapping = machineState.axialCenterDrilling ? 84 : 84;
Re: Custom G code
Hi
What CAM system You Have?
Do You have PP generator manual?
That piece of Code - could You send full file?
We have done PP's more than 30 years for different
CAM systems as a service. So We can help you.
BG. [email]Tapio.Saarinen@titako.fi[/email]
- Custom G code
- You may not post replies
- You may not edit your posts
Forum Rules
