Solved Siemens 828d Vectric Mill Post Procssor
Results 1 to 1 of 1
Thread: Siemens 828d Vectric Mill Post Procssor
    Jun 2016
    New Zealand
    Default Siemens 828d Vectric Mill Post Procssor
    Hi all I have created a Post Processor for Vectric to create 3axis Mill output for Siemens 828d. Have tested it and it appears to work well.
    As vectric does not have a coolant option (that I have found) I have set coolant "on" by default for each tool. You will need to open either the PP or the output file and remove the M8,s to turn of the coolant.
    For this PP to work your Tool names in vectric must appear as, including speech marks and Capitals "TOOLNAME" ie "ENDMILL10MM"
    This PP is not available in vectrics PP folder and I put in some effort to get it edited. I would like to share the file to save others the hassle.
    So please share and enjoy.
    Attached Files Attached Files
