No I don't think so. The following G code is your toolpath from above converted to line segments, with 0.01'' resolution, rather than using G2, G3 moves for the arcs.
N15 G17
N20 M3 S1000
N25 G0 Z0.5
N30 G0 X0.1 Y-0.0875
N35 G0 Z0.0625
N40 G1 F5.0 Z-0.06
N45 G1 X0.0396 Y-0.0775
N50 G1 X-0.0144 Y-0.0486
N55 G1 X-0.0562 Y-0.0038
N60 G1 X-0.0813 Y0.0521
N65 G1 X-0.0875 Y0.1
N70 G1 X-0.0775 Y0.5011
N75 G1 X-0.0476 Y0.9012
N80 G1 X0.0022 Y1.2994
N85 G1 X0.0719 Y1.6945
N90 G1 X0.1611 Y2.0857
N95 G1 X0.2697 Y2.472
N100 G1 X0.3974 Y2.8524
N105 G1 X0.5439 Y3.2259
N110 G1 X0.7088 Y3.5917
N115 G1 X0.8918 Y3.9488
N120 G1 X1.0923 Y4.2963
N125 G1 X1.3099 Y4.6335
N130 G1 X1.5441 Y4.9593
N135 G1 X1.7941 Y5.2731
N140 G1 X2.0595 Y5.574
N145 G1 X2.3396 Y5.8614
N150 G1 X2.4717 Y5.9874
N155 G1 X2.7513 Y6.2618
N160 G1 X3.0166 Y6.5501
N165 G1 X3.2668 Y6.8515
N170 G1 X3.5013 Y7.1654
N175 G1 X3.7194 Y7.4908
N180 G1 X3.9207 Y7.8269
N185 G1 X4.1046 Y8.1729
N190 G1 X4.2705 Y8.5277
N195 G1 X4.4182 Y8.8906
N200 G1 X4.5471 Y9.2606
N205 G1 X4.657 Y9.6366
N210 G1 X4.7475 Y10.0178
N215 G1 X4.8185 Y10.4031
N220 G1 X4.8698 Y10.7915
N225 G1 X4.9011 Y11.182
N230 G1 X4.9125 Y11.5736
N235 G1 Y11.6
N240 G1 X4.9025 Y11.9917
N245 G1 X4.8724 Y12.3823
N250 G1 X4.8225 Y12.7709
N255 G1 X4.7529 Y13.1565
N260 G1 X4.6636 Y13.538
N265 G1 X4.555 Y13.9144
N270 G1 X4.4273 Y14.2848
N275 G1 X4.2809 Y14.6482
N280 G1 X4.1161 Y15.0037
N285 G1 X3.9335 Y15.3503
N290 G1 X3.7333 Y15.6871
N295 G1 X3.5162 Y16.0133
N300 G1 X3.2828 Y16.3279
N305 G1 X3.0336 Y16.6303
N310 G1 X2.7693 Y16.9195
N315 G1 X2.4906 Y17.1949
N320 G1 X2.4717 Y17.2126
N325 G1 X2.1851 Y17.4936
N330 G1 X1.913 Y17.7884
N335 G1 X1.6559 Y18.0965
N340 G1 X1.4144 Y18.417
N345 G1 X1.1892 Y18.7491
N350 G1 X0.9809 Y19.092
N355 G1 X0.7899 Y19.4449
N360 G1 X0.6167 Y19.8069
N365 G1 X0.4617 Y20.177
N370 G1 X0.3254 Y20.5544
N375 G1 X0.2081 Y20.9382
N380 G1 X0.11 Y21.3273
N385 G1 X0.0315 Y21.7208
N390 G1 X-0.0274 Y22.1177
N395 G1 X-0.0664 Y22.517
N400 G1 X-0.0854 Y22.9179
N405 G1 X-0.0875 Y23.1
N410 G1 X-0.0775 Y23.1604
N415 G1 X-0.0486 Y23.2144
N420 G1 X-0.0038 Y23.2562
N425 G1 X0.0521 Y23.2813
N430 G1 X0.1 Y23.2875
N435 G1 X23.1
N440 G1 X23.1604 Y23.2775
N445 G1 X23.2144 Y23.2486
N450 G1 X23.2562 Y23.2038
N455 G1 X23.2813 Y23.1479
N460 G1 X23.2875 Y23.1
N465 G1 X23.2775 Y22.6989
N470 G1 X23.2476 Y22.2988
N475 G1 X23.1978 Y21.9006
N480 G1 X23.1281 Y21.5055
N485 G1 X23.0389 Y21.1143
N490 G1 X22.9303 Y20.728
N495 G1 X22.8026 Y20.3476
N500 G1 X22.6561 Y19.9741
N505 G1 X22.4912 Y19.6083
N510 G1 X22.3082 Y19.2512
N515 G1 X22.1077 Y18.9037
N520 G1 X21.8901 Y18.5665
N525 G1 X21.6559 Y18.2407
N530 G1 X21.4059 Y17.9269
N535 G1 X21.1405 Y17.626
N540 G1 X20.8604 Y17.3386
N545 G1 X20.7283 Y17.2126
N550 G1 X20.4487 Y16.9382
N555 G1 X20.1834 Y16.6499
N560 G1 X19.9332 Y16.3485
N565 G1 X19.6987 Y16.0346
N570 G1 X19.4806 Y15.7092
N575 G1 X19.2793 Y15.3731
N580 G1 X19.0954 Y15.0271
N585 G1 X18.9295 Y14.6723
N590 G1 X18.7818 Y14.3094
N595 G1 X18.6529 Y13.9394
N600 G1 X18.543 Y13.5634
N605 G1 X18.4525 Y13.1822
N610 G1 X18.3815 Y12.7969
N615 G1 X18.3302 Y12.4085
N620 G1 X18.2989 Y12.018
N625 G1 X18.2875 Y11.6264
N630 G1 Y11.6
N635 G1 X18.2975 Y11.2083
N640 G1 X18.3276 Y10.8177
N645 G1 X18.3775 Y10.4291
N650 G1 X18.4471 Y10.0435
N655 G1 X18.5364 Y9.662
N660 G1 X18.645 Y9.2856
N665 G1 X18.7727 Y8.9152
N670 G1 X18.9191 Y8.5518
N675 G1 X19.0839 Y8.1963
N680 G1 X19.2665 Y7.8497
N685 G1 X19.4667 Y7.5129
N690 G1 X19.6838 Y7.1867
N695 G1 X19.9172 Y6.8721
N700 G1 X20.1664 Y6.5697
N705 G1 X20.4307 Y6.2805
N710 G1 X20.7094 Y6.0051
N715 G1 X20.7283 Y5.9874
N720 G1 X21.0149 Y5.7064
N725 G1 X21.287 Y5.4116
N730 G1 X21.5441 Y5.1035
N735 G1 X21.7856 Y4.783
N740 G1 X22.0108 Y4.4509
N745 G1 X22.2191 Y4.108
N750 G1 X22.4101 Y3.7551
N755 G1 X22.5833 Y3.3931
N760 G1 X22.7383 Y3.023
N765 G1 X22.8746 Y2.6456
N770 G1 X22.9919 Y2.2618
N775 G1 X23.09 Y1.8727
N780 G1 X23.1685 Y1.4792
N785 G1 X23.2274 Y1.0823
N790 G1 X23.2664 Y0.683
N795 G1 X23.2854 Y0.2821
N800 G1 X23.2875 Y0.1
N805 G1 X23.2775 Y0.0396
N810 G1 X23.2486 Y-0.0144
N815 G1 X23.2038 Y-0.0562
N820 G1 X23.1479 Y-0.0813
N825 G1 X23.1 Y-0.0875
N830 G1 X0.1
N835 G0 Z0.5
N840 M5
If it's a rack and pinion machine, then something is loose.
UCCNC 2017 Screenset
Gerry,
It has ballscrews on all axis, and they are an inch in diameter. The only time I seem to get this kind of 'hiccup' is at the intersection point between elements.
Might be some WinCNC parameters then??
I think I have finally solved this and it looks like you were mostly right--WinCNC parameters in the .ini file. Here's the optimum configuration which effectively eliminates a 'bump' at the intersection of two arcs in opposing direction, in order of importance:
1. Autoarcfeed = F70
2. G09 = 80
3. Spoilboard foam. I was just using foam gasketing from HomeDepot but had a conversation with the guy that runs this site: All Star Adhesives - gasketing products for CNC routers and v-groove tape for v-grooving and coving applications
and went with a 0.25" thick foam that is put in a machined channel that is 0.19" thick, leaving 0.06" of foam exposed above the table surface. My problem is that my foam was previously a much larger distance above the table and this allows for the workpiece to move during machining, and especially during direction changes.
Indeterminate or no effect:
1. Acceleration = S20
2. Arctype =T2
3. Use the ShopSabre post-processor
