Mach3 post Processor for MasterCam 2022.... if existing ?
Results 1 to 5 of 5
Thread: Mach3 post Processor for MasterCam 2022.... if existing ?
    Member Robert M's Avatar
    Oct 2006
    Default Mach3 post Processor for MasterCam 2022.... if existing ?
    1st, should be; does anyone knows if there such thing, a Post P from MC-2022 to post on Mach3 ?
    I know Mach3 is passé, but still have it & enjoy it after 15yrs.
    Tried to migrate from MC2017 to MC2019.....will simply not ??
    Any leads, direction would be much appreciate.
    Member gabedrummin's Avatar
    Aug 2008
    united sates
    Default Re: Mach3 post Processor for MasterCam 2022.... if existing ?
    A standard Fanuc post works with some editing .When threading I use G32 the Fanuc post an E for the Feed change those E to F other than that I dont have to change much guess it just depends how many axis your using and what your machine is doing .
    Oct 2006
    Thks gab !....will see how & if !!,
    Since not my "expertise" to play (changing post steps) output ( or the processor programming output) !..... would rather / hope for continuing using simple Mach3 PP
    But a guess, like many, much evolve that part to
    Oct 2006
    Quote Originally Posted by gabedrummin View Post
    Hey Gab.... how do you get your changing from E to F "automatically"....avoiding manual changes to all.....
    tedious if you have a few thousand G-code lines !!
    Aug 2008
    united sates
    From the g-code editor .under edit , use the replace all fuction.
