Problem how can i make this program on master cam
Results 1 to 12 of 12
Thread: how can i make this program on master cam
    Feb 2010
    pakistan
    Default how can i make this program on master cam
    how can i make this program on master cam please advise me
    N0000 T0202
    N0010 M3 S1000
    N0020 G0 X-18 Z5
    N0030 Z2
    N0040 Z1
    N0050 G72 X-2.2 I0.1 K0.3 P0080 Q0090 F115
    N0060 G0 X-18
    N0070 Z5
    N0080 G1 X-2.2 F80
    N0090 Z-9.9
    N0100 G1 X-6
    N0110 Z-11.1
    N0120 G1 X-15
    N0130 Z-12
    N0140 G0 X-18
    N0150 Z5
    N0160 M30
    Member awerby's Avatar
    Apr 2004
    Default Re: how can i make this program on master cam
    If you've already got the G-code, you don't need MasterCAM; just open it in the machine control program and run it. CAM programs like MasterCAM are for converting models or drawings into toolpaths which they then convert to G-code that runs on your machine.
    Feb 2010
    pakistan
    Thanks to reply me......
    sir i can use MasterCAM and i want to make the program off line with model when we generate the G Code from MasterCAM and send the machine, my machine not accept this MasterCam program... just i want to make program off line..... please help me.... again thanks
    Master Cam Program..
    N110 G0 T2020
    N120 G18
    N130 G97 S3600 M03
    N140 G0 G54 X-18. Z5.
    N150 G50 S3600
    N160 G96 S550
    N2980 G71 U.1 R.2
    N2990 G71 P3000 Q3050 I0.1 K0.5 F.50
    N3000 G0 X-2.2 S550
    N3010 G1 Z-9.9
    N3020 X-5.6
    N3030 G2 X-6. Z-10.1 K-.2
    N3040 G1 Z-11.1
    N3050 X-16.
    N3060 G0 Z5.
    N3160 M30
    Machine Controller Program (machine accept and work)
    N0000 T0202
    N0010 M3 S1000
    N0020 G0 X-18 Z5
    N0030 Z2
    N0040 Z1
    N0060 G0 X-18
    N0070 Z5
    N0080 G1 X-2.2 F80
    N0090 Z-9.9
    N0100 G1 X-6
    N0110 Z-11.1
    N0120 G1 X-15
    N0130 Z-12
    N0140 G0 X-18
    N0150 Z5
    N0160 M30
    advise me post processor
    Feb 2010
    pakistan
    i have controller GSK 928 tea
    Member routalot's Avatar
    Dec 2003
    The G18 in the Mastercam program suggests that you are creating the program in the XZ plane.Is that what you intended?
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Not really clear what your request is...
    Are you wanting to run the .mcam file on the machine ?
    or
    You want to modify the post processor to output a different .NC file that does make your machine run ?
    or
    Advice on what operation to use to get the desired .NC code ie G72 instead of G71 ?
  7. #7
    Feb 2010
    pakistan
    i want to run MasterCAM Program....
    i want to modify the post processor as per my machine controller program......
  8. #8
    Feb 2010
    pakistan
    Quote Originally Posted by Superman View Post
    or
    or
  9. #9
    Dec 2008
    Antarctica
    Quote Originally Posted by ADNAN View Post
    OK... I'll bite
    Do you know how to program a lathe toolpath in Mastercam ?
    G71 is a turning op, G72 is facing.... it appears it is programmer training problem, not a post mod requirement
    ...you need to correctly set the operation parameters to get the correct NC output. Or select the correct contour.
  10. #10
    Activation process
    Sep 2019
    I think you need to make a sample .mcam file on mastercam and a good program that works on your machine and post them in here.
    I think your post in mastercam rightnow has a problem.
  11. #11
    Feb 2010
    pakistan
    Quote Originally Posted by dannytnguyen89 View Post
    I have to make a program like this on master cam please help me i think i need to change the postprossar.....
    N0000 T0202
    N0010 M3 S1000
    N0020 G0 X-18 Z5
    N0030 Z2
    N0040 Z1
    N0060 G0 X-18
    N0070 Z5
    N0080 G1 X-2.2 F80
    N0090 Z-9.9
    N0100 G1 X-6
    N0110 Z-11.1
    N0120 G1 X-15
    N0130 Z-12
    N0140 G0 X-18
    N0150 Z5
    N0160 M30
  12. #12
    Feb 2010
    pakistan
    OK... I'll bite
    N0000 T0202
    N0010 M3 S1000
    N0020 G0 X-18 Z5
    N0030 Z2
    N0040 Z1
    N0060 G0 X-18
    N0070 Z5
    N0080 G1 X-2.2 F80
    N0090 Z-9.9
    N0100 G1 X-6
    N0110 Z-11.1
    N0120 G1 X-15
    N0130 Z-12
    N0140 G0 X-18
    N0150 Z5
    N0160 M30
